Hi Guys.
I'm trying out a stm32f103c8t6 mini dev board with an ST-Link/V2 programmer.
http://www.ebay.com/itm/ARM-Development-Board-Cortex-M3-STM32F103C8T6-STM32-Module-8Mhz-USB-JTAG-ISP-USA-/161213419355I'm having trouble using IAR 6.5 when debugging. I get this error "Failed to setup call to 'FlashInit' " when the use flash loader is checked.
Fri Aug 22, 2014 13:41:47: Loaded macro file: C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.5\arm\config\flashloader\ST\FlashSTM32F10xxx.mac
Fri Aug 22, 2014 13:41:47: Selecting SWD as current target interface.
Fri Aug 22, 2014 13:41:47: Hardware reset with strategy 0 was performed
Fri Aug 22, 2014 13:41:47: Initial reset was performed
Fri Aug 22, 2014 13:41:47: -I- execUserFlashInit!
Fri Aug 22, 2014 13:41:47: 456 bytes downloaded (5.71 Kbytes/sec)
Fri Aug 22, 2014 13:41:47: Loaded debugee: C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.5\arm\config\flashloader\ST\FlashSTM32F10xxxRAM32K.out
Fri Aug 22, 2014 13:41:47: Target reset
Fri Aug 22, 2014 13:41:47: Flash loader: Failed to setup call to 'FlashInit'" Can some point me in the right direction please.
