Author Topic: PIC32 DMA ADC. Single channel to transfer two ADC buffer  (Read 1715 times)
Offline satyamfifaTopic starter
« on: September 19, 2019, 12:14:50 am »
Hey All,
I am using PIC32MX460F512L, I am using ADC in ALT mode to sample two ADC pins and 1 interrupts for 2 conversions. I am thinking of copying the results of 2 conversion into RAM using DMA. Therefore I was wondering if it possible to use a single DMA channel to copy the result of ADC1BUF0 and AD1BUF1 without CPU intervention. I want to know if it is possible and how.
Thanks in advance.
Regards,
Sparsh
Offline nigelwright7557
    • Electronic controls
Re: PIC32 DMA ADC. Single channel to transfer two ADC buffer
« Reply #1 on: September 19, 2019, 02:53:04 am »
I found the time taken between the samples gave me ample time to put the data into buffers.
I found using the DMA took longer.
Offline mikerj
« Reply #2 on: September 19, 2019, 09:29:47 am »
DMA is useful to move large amounts of data around whilst the CPU works on something else.  You still have a service an interrupt when the DMA has completed, and re-set the DMA for the next transfer so like Nigel says it's likely you will increase CPU overhead compared to simply servicing the ADC interrupt.
