Author Topic: cheap lidar, kit rplidar 360 laser scanner, what do you think about ?  (Read 12225 times)
Offline legacyTopic starter
kit rplidar 360 laser scanner (300/400 euro)
Re: cheap lidar, kit rplidar 360 laser scanner, what do you think about ?
« Reply #1 on: October 19, 2014, 04:26:51 pm »
the motor is 300rpm
no idea about its MBTF
and no idea about the sleep ring
anybody here has tested/tried this kit and can provide a reasonable feedback ?
« Reply #2 on: October 19, 2014, 08:42:30 pm »
seedstudio is selling the whole kit
« Reply #3 on: October 19, 2014, 08:53:31 pm »
i have found this project
« Reply #4 on: October 19, 2014, 08:58:29 pm »
and this information
and this hack
and this other hack
and this pretty page that tells something about the sleep ring
« Last Edit: October 20, 2014, 12:16:09 am by legacy »
Offline miguelvp
« Reply #5 on: October 19, 2014, 09:13:10 pm »
Looks cool.
I would have use a prism mounted on a gyroscope and leave the laser and detector fixed and add also tilt control to get more than just a 2d section.
I hope the laser is safe or it will blind your pets :)
« Reply #6 on: October 20, 2014, 12:23:43 am »
this quote is the summary, what is/who did it/etc
Neato Robotics Hacking, 2014
This site is devoted mainly to iRobot hacking. Just for reference extensive Neato hacking has been developed you can find in Google search. The interest has been in using the lidar out of the Neato, and interfacing Neato's system to other robotics control systems (not so much interest to vacuum users). Complete software packages have been developed, e.g.
https://www.labviewhacker.com/doku.php?id=projects:lv_neatolds_interface:lv_neatolds_interface
http://www.ros.org/news/2011/02/neato-xv-11-laser-driver.html
Interesting the technical details of Neato's lidar invention was described in an engineering journal article posted at RobotShop http://www.robotshop.com/media/files/PDF/revolds-whitepaper.pdf
As initial sales promotion when Neato was introduced several years ago, Neato encouraged hacking the lidar and held a contest for it, to stimulate exposure. Now the results have been polished into full software packages. The company still does not sell the lidar unit separately for robotics -- to help sell vacuums...
[edit] another Neato post this section on adding bluetooth (possible only on older system boards including a serial interface header besides the USB) http://www.robotreviews.com/chat/viewtopic.php?f=4&t=15349
Neato labels board several ways including a display on the LCD, with older boards showing up to 113, and hand marked Rev.7 on the board, and Rev.1 on silkscreen. Old and new photos:
old with serial http://xv11hacking.wikispaces.com/XV-11+PCB+Information
New without: http://xv11hacking.wikispaces.com/PCB+rev.+64
(Besides the port change the major incompatibilities are a new charger system incompatible with old chargers, backwards compatible new, and a pin connector for the LCD cable instead of the bare ribbon cable clamp.)
glnc222
As a result of the initial XV-11 hacking frenzy, you can obtain a complete Lidar unit for your Neato for under $100 with free shipping from ebay and can sometimes find Lidar sellers w/shipping for around the same price on Amazon.
« Reply #7 on: October 23, 2014, 04:52:18 pm »
anybody has the following paper ?
Cover story in the September, 1993 Sensors magazine.
Frequency-Modulated Laser Ranging by Neal Woodbury & Michael Brubacher
in case, could you contact me by private message ?
« Reply #8 on: October 27, 2014, 07:38:38 am »
anybody with experience in this things ?
« Reply #9 on: October 31, 2014, 07:59:42 am »
laser rangefinder, OSLRF-01 model
have you seen this ?
The OSLRF-01 is an open source laser range sensor that works on the time-of-flight principle. It includes a laser, detector, optics and sequential-equivalent-time-sampling (SETS) circuits. Designed as a bare-metal front end for a laser rangefinder system, the OSLRF-01 is a high quality sensor that can interface directly to the ADC channels of a micro controller. The OSLRF-01 is ideal for obstacle detection, distance measurement and laser rangefinder research.
Offline miguelvp
« Reply #10 on: October 31, 2014, 08:19:38 am »
Nice.
Too bad the OSLRF-01 is not available
http://www.lightware.co.za/shop/en/4-lrf-modules
but.... The kit is for just $32 (No laser, nor components, I'm afraid)
http://www.lightware.co.za/shop/en/lrf-components/26-oslrf-01-kit.html
But the downloads has a manual with the BOM
also some laser diodes listed on their site:
http://www.lightware.co.za/shop/en/5-lrf-components
« Reply #11 on: October 31, 2014, 08:33:43 am »
yeah, we could still assembly the circuit by ourself  ;D
just wandering WHY not to use the phase drift method instead of time of flight one :-//
« Reply #12 on: October 31, 2014, 09:46:08 am »
Line Scan Image Sensor Demonstration Kit
LIS-1024, LIS-500, RPLIS-2048, ELIS-1024, DLIS-2K/4K and SLIS-2048
also, have you seen the Line Scan Image Sensor Demonstration Kit ?
This kind of technology is a sort of super reflective angle LIDAR,
an idea that makes things simpler and cheaper, Neato has used this idea for their $50 USD LIDAR.
« Reply #13 on: November 04, 2014, 08:09:54 pm »
the lr4 is a 150USD LASER RANGEFINDER which could be used in robotic things, and it could be used as lidar if used with a rotating base, in case just to make you known about its existence  :D
