Author Topic: MachXO3LF FTDI issue?  (Read 1925 times)
Offline peepoTopic starter
« on: December 18, 2015, 07:04:19 pm »
further hints please:
following MachXO3StarterKitUsersGuideEB95.pdf
diamond installed and runs on Ubuntu 14.04 following guide:
http://www.lemongrass-studio.net/main/node/73
downloaded blink source
http://www.latticesemi.com/view_document?document_id=51476
built bitfile ?
but do not get status PASS when clicking programmer
tried changing udev rules without result
Starting: "prj_project open "/home/jay_jetson/FPGA/Lattice/MachXO3LF_Starter_Kit/project/Blink.ldf""
Starting: parse design source files
(VERI-1482) Analyzing Verilog file /usr/local/diamond/3.6_x64/ispfpga/userware/unix/SYNTHESIS_HEADERS/machxo3l.v
(VERI-1482) Analyzing Verilog file /home/jay_jetson/FPGA/Lattice/MachXO3LF_Starter_Kit/source/heartbeat.v
(VERI-1482) Analyzing Verilog file /home/jay_jetson/FPGA/Lattice/MachXO3LF_Starter_Kit/source/kitcar.v
(VERI-1482) Analyzing Verilog file /home/jay_jetson/FPGA/Lattice/MachXO3LF_Starter_Kit/source/XO3L_SK_blink.v
INFO - /home/jay_jetson/FPGA/Lattice/MachXO3LF_Starter_Kit/source/XO3L_SK_blink.v(70,8-70,21) (VERI-1018) compiling module XO3L_SK_blink
INFO - /home/jay_jetson/FPGA/Lattice/MachXO3LF_Starter_Kit/source/XO3L_SK_blink.v(70,1-168,10) (VERI-9000) elaborating module 'XO3L_SK_blink'
INFO - /usr/local/diamond/3.6_x64/ispfpga/userware/unix/SYNTHESIS_HEADERS/machxo3l.v(1759,1-1764,10) (VERI-9000) elaborating module 'OSCH_uniq_1'
INFO - /home/jay_jetson/FPGA/Lattice/MachXO3LF_Starter_Kit/source/heartbeat.v(73,1-128,10) (VERI-9000) elaborating module 'heartbeat_uniq_1'
INFO - /home/jay_jetson/FPGA/Lattice/MachXO3LF_Starter_Kit/source/kitcar.v(73,1-165,10) (VERI-9000) elaborating module 'kitcar_uniq_1'
Done: design load finished with (0) errors, and (0) warnings
Lattice VM Drivers detected (HW-USBN-2B (FTDI))
Programmer device database loaded
Starting: "pgr_project open "/home/jay_jetson/FPGA/Lattice/MachXO3LF_Starter_Kit/project/impl1/impl1.xcf""
lsusb
Bus 003 Device 037: ID 0403:6010 Future Technology Devices International, Ltd FT2232C Dual USB-UART/FIFO IC
dmesg
[1320050.427845] usb 3-2: Product: Lattice XO3LF Starter Kit
[1320050.427850] usb 3-2: Manufacturer: Lattice
[1320050.430843] ftdi_sio 3-2:1.0: FTDI USB Serial Device converter detected
[1320050.430903] usb 3-2: Detected FT2232H
[1320050.430908] usb 3-2: Number of endpoints 2
[1320050.430912] usb 3-2: Endpoint 1 MaxPacketSize 512
[1320050.430917] usb 3-2: Endpoint 2 MaxPacketSize 512
[1320050.430921] usb 3-2: Setting MaxPacketSize 512
[1320050.431109] usb 3-2: FTDI USB Serial Device converter now attached to ttyUSB0
[1320050.433744] ftdi_sio 3-2:1.1: FTDI USB Serial Device converter detected
[1320050.433792] usb 3-2: Detected FT2232H
[1320050.433797] usb 3-2: Number of endpoints 2
[1320050.433801] usb 3-2: Endpoint 1 MaxPacketSize 512
[1320050.433806] usb 3-2: Endpoint 2 MaxPacketSize 512
[1320050.433810] usb 3-2: Setting MaxPacketSize 512
[1320050.433996] usb 3-2: FTDI USB Serial Device converter now attached to ttyUSB1
Offline NickAmes
Re: MachXO3LF FTDI issue?
« Reply #1 on: January 11, 2016, 05:14:00 am »
With a MachXO2 board, also on Ubuntu 14.04, I need to run sudo modprobe -r ftdi_sio to get the FTDI JTAG programmer to work.
