I wouldn't use the Cypress USB Serial Test program for the final implementation but you could write a program using WinUSB for the last two steps.
Here is the setup of the breakoff part of the PSoC4100 prototype board with a CY7C65211-24LTXI single channel interface (CY7C65215 has dual channels, but not in this prototype board) Also I didn't want to break-off the one in the PSoC4200, but the USB-Serial part is the same for both $4 prototype boards.
I have an RTC board that uses an NXP PCF8563 that uses I2C at 400KHz
![](https://www.eevblog.com/forum/microcontrollers/cheap-easy-i2c-dev-kit/?action=dlattach;attach=138818;image)
I already have all the software and drivers installed so I'm not going to go through that.
So first I open the Cypress USB-Serial Configuration Utility after plugin in the board to my PC USB port, and selected my USB-Serial (Single Channel) target and clicked on Connect:
![](https://www.eevblog.com/forum/microcontrollers/cheap-easy-i2c-dev-kit/?action=dlattach;attach=138820;image)
I left the USB configuration alone, but you can change the VID/PID manufacturer and product strings etc, also left the IO levels to CMOS (you can select TTL) and clicked on the SCB tab:
![](https://www.eevblog.com/forum/microcontrollers/cheap-easy-i2c-dev-kit/?action=dlattach;attach=138822;image)
Next I selected the mode to be I2C and clicked Configure
![](https://www.eevblog.com/forum/microcontrollers/cheap-easy-i2c-dev-kit/?action=dlattach;attach=138824;image)
Edit: Note that you can set the notification LEDs to use GPIO pins to drive transmit and receive individual LEDs or a single one for both tx/rx
Selected 400KHz and set it to be in Master mode and ok.
![](https://www.eevblog.com/forum/microcontrollers/cheap-easy-i2c-dev-kit/?action=dlattach;attach=138826;image)
Back to the previous screen click on program.
![](https://www.eevblog.com/forum/microcontrollers/cheap-easy-i2c-dev-kit/?action=dlattach;attach=138828;image)
And it will come back with success (if everything is setup right).
![](https://www.eevblog.com/forum/microcontrollers/cheap-easy-i2c-dev-kit/?action=dlattach;attach=138830;image)
Now, since I can't be bothered to write a WinUSB sample program, I just used the provided USB Serial Test Utility from Cypress, but you really wan't to write your own and talk to your VID/PID or search for your custom manufacturer and/or product string when enumerating USB devices.
But this test utility will allow me to just read the RTC, Also I didn't bother to program this RTC so it's as it came from China because I never had time to play with it until now, but just wanted to see if I could read data from it using this USB-Serial chip.
So I started the test utility and changed the Vendor ID and Product ID to what I programmed the chip with.
![](https://www.eevblog.com/forum/microcontrollers/cheap-easy-i2c-dev-kit/?action=dlattach;attach=138832;image)
Then clicked the Read & verify data, and of course the verify part didn't work but it displays what the RTC is sending at 400KHz
![](https://www.eevblog.com/forum/microcontrollers/cheap-easy-i2c-dev-kit/?action=dlattach;attach=138834;image)
The bus pirate might have easier tools, but for the price ($4 plus you get to keep an Cortex M0 ARM processor) it's a good alternative, you can't even buy the chip and make your own board for the fraction of that break off board that comes with that prototyping board.
Edit: You can also program the CapSense for capacitance touch, and unsused GPIOs mode on top of the Battery Charge Detect for battery powered devices.
