I'm not sure I understand your reply regarding using the 'interrupt' attribute. Did the patched version change the behavior of the 'interrupt' attribute itself?
I'd have assumed they had only *added* a specific attribute (WCH-Interrupt-fast), but didn't change the existing 'interrupt' behavior, so that one could use either, even with their patched version, and the latter without any change compared to mainline gcc. Is it not the case?
They're not going to duplicate the entire code generation apparatus, but just patch a little bit in the prologue and epilog generation. The question is which existing version their new attribute builds on.
I would have thought that keeping the original behavior of the 'interrupt' attribute itself, and only changing it for the new, vendor attribute 'WCH-Interrupt-fast' - would have made sense. Breaking existing behavior is bad.
Without it having to mean a particularly complicated patch. So that one could still use either and have either behavior. But what have they done, who knows. Where is the patch (if you or someone else has a link?)
FFS. It DOES NOT break existing behaviour. With the patch you have normal functions, __attribute__((interrupt)) functions, and __attribute__((WCH-Interrupt-fast)) functions.
The QUESTION is: which of the first two is the latter a modification of?
Clear enough?
Not really. I'm sure it comes from a misunderstanding of what exactly each other means, adding to that the fact that you have worked on GCC, so some things may look obvious to you when they aren't necessarily to others.
What I was meaning by "existing behavior" is the behavior of mainline GCC when using the interrupt attribute with a RISC-V rv32imafc target. I'm assuming that it has a common behavior in all cases, unless you specify another attribute than the bare "interrupt" one. Maybe that's not exactly how things are implemented for RISC-V targets, so let me know if this isn't the case.
Going from there, my assumption was that if WCH's patched version behaves identically to mainline GCC when using the bare "interrupt" attribute, then it should not make any difference whether you use mainline GCC or their patched version, if using this attribute. That sounds logical to me. Maybe it isn't to GCC. Or maybe we weren't talking about the same thing.
You last question "which of the first two is the latter a modification of?" leaves me puzzled instead of being clear to me, but that's possibly because you have hands-on experience developing back-ends for GCC when I don't.
As a user - not a GCC developer - I would logically think that WCH would have piggybacked on the existing RISC-V back-end, leaving the "interrupt" behavior as is, and switching to their own behavior when specifying the "WCH-Interrupt-fast" attribute instead. So I don't understand the question. But that may again be because something extremely obvious to you in the way GCC back-ends are structured in general, and the status with the RISC-V one in particular, is not to me.
So without a detailed knowledge of GCC internals, my naive view is that if the "interrupt" attribute on their patched version doesn't exactly behave as the "interrupt" attribute on mainline GCC, then that's what I was calling "breaking existing behavior". The only thing that may be the missing piece here - again probably 100% obvious to you and not to me - is that the bare "interrupt" behavior may be dependent on the extra extensions WCH has defined (when using -march=rv32imacxw), while I'm sticking to "rv32imafc". If so, that would look a bit messy to me. If not, then I still don't get it, and so I'm probably dense. (Btw, I suppose their extension is "w", but what is "x"? or maybe it's "xw"? Oh and they don't seem to enable FP support in their example makefiles. Go figure.)
And with all that said, it looks like WCH still hasn't released the source code for their patch, unless I've missed it. At least that's what appears to be the case on their openwch github, with an unanswered ticket from some user. Which doesn't bode too well to me. But I'll stick to mainline GCC anyway. At least until they relase their patch. And if they have, I'll be glad to have a look. Popcorn time.
