Author Topic: CH32V307 Evaluation Board RISC-V  (Read 719 times)
Offline badbyteTopic starter
« on: June 08, 2023, 08:17:51 pm »
Hi people,
I have bought on aliexress an evaluation board for the CH32V307 here.
I have bought 2 of those and one showed up with the following lsusb output:
Bus 001 Device 012: ID 1a86:8010 QinHeng Electronics WCH-Link
And the other showed up in lsusb as follows:
Bus 001 Device 011: ID 4348:55e0 WinChipHead
The second one doesn't respond to eclipse's queries at all, in the Configuration of the Download Configuration.
From the output of lsusb I conclude that the firmware on the 2nd isn't the proper one.
Can someone pointme to the right direction???
« Last Edit: June 08, 2023, 08:30:33 pm by badbyte »
Offline GromBeestje
Re: CH32V307 Evaluation Board RISC-V
« Reply #1 on: June 13, 2023, 09:23:01 pm »
This looks to me like one of the boards gets into the debugger firmware, and the other baord is stuck in bootloader mode.
WinChipHead has a Windows-only tool to configure and update their programmers, the dongles and the built-in EVB boards alike.
Try the tool at https://www.wch.cn/downloads/WCH-LinkUtility_ZIP.html and see if it can configure the boards to RISCV debugger mode.
