I have a project in which I'm looking to replace an ATTINY85 with a CH32V003J4M6. It'll use three buttons to control a PWM output: increase duty cycle, decrease duty cycle, toggle on/off.
I have some chips on order, but in the meantime I have an eval board with a CH32V003F4P6 on it. Its capabilities are a superset of what I'm eventually targeting, so I can get to work wrapping my head around the different libraries that are available and figure out which one works best. So far, I'm gravitating toward the ch32v003fun library, as it seems simple enough to do what I need it to do. I've already run several of the examples: blink, GPIO, tim1_pwm, and probably some others. I/O on the J4M6 is limited, so I'd like to be able to use PA1 and PA2 if necessary (I'll be running it without a crystal).
As it happens, while the CH32V003F4P6-R0-1v1 eval board does have a crystal on it, it's not actually connected by default. If I'm reading the schematic right, R4 and R5 need to be populated with jumpers to use the crystal. Every attempt at using PA1 and PA2 for output, though, has failed.
Here's the ch32v003fun blink program, tweaked to hopefully toggle PA1 and PA2 along with some PC* and PD* pins:
#include "ch32v003fun.h"
#include <stdio.h>
int main()
SystemInit();
// enable GPIO on A1 and A2
AFIO->PCFR1 &= ~GPIO_Remap_PA1_2;
// Enable GPIOs
RCC->APB2PCENR |= RCC_APB2Periph_GPIOD | RCC_APB2Periph_GPIOC | RCC_APB2Periph_GPIOA;
// GPIO A1 Push-Pull
GPIOA->CFGLR &= ~(0xf<<(4*1));
GPIOA->CFGLR |= (GPIO_Speed_10MHz | GPIO_CNF_OUT_PP)<<(4*1);
// GPIO A2 Push-Pull
GPIOA->CFGLR &= ~(0xf<<(4*2));
GPIOA->CFGLR |= (GPIO_Speed_10MHz | GPIO_CNF_OUT_PP)<<(4*2);
// GPIO D0 Push-Pull
GPIOD->CFGLR &= ~(0xf<<(4*0));
GPIOD->CFGLR |= (GPIO_Speed_10MHz | GPIO_CNF_OUT_PP)<<(4*0);
// GPIO D4 Push-Pull
GPIOD->CFGLR &= ~(0xf<<(4*4));
GPIOD->CFGLR |= (GPIO_Speed_10MHz | GPIO_CNF_OUT_PP)<<(4*4);
// GPIO D6 Push-Pull
GPIOD->CFGLR &= ~(0xf<<(4*6));
GPIOD->CFGLR |= (GPIO_Speed_10MHz | GPIO_CNF_OUT_PP)<<(4*6);
// GPIO C0 Push-Pull
GPIOC->CFGLR &= ~(0xf<<(4*0));
GPIOC->CFGLR |= (GPIO_Speed_10MHz | GPIO_CNF_OUT_PP)<<(4*0);
while(1)
GPIOD->BSHR = (1<<0) | (1<<4) | (1<<6); // Turn on GPIOs
GPIOC->BSHR = (1<<0);
GPIOA->BSHR=(1<<1) | (1<<2);
Delay_Ms( 250 );
GPIOD->BSHR = (1<<16) | (1<<(16+4)) | (1<<(16+6)); // Turn off GPIOs
GPIOC->BSHR = (1<<16);
GPIOA->BSHR=(1<<(16+1)) | (1<<(16+2));
Delay_Ms( 250 );
I hoped that the line that clears the GPIO_Remap_PA1_2 bit in AFIO->PCFR1 would ensure that PA1 and PA2 were set up as GPIO pins instead of clock pins, and then the rest was a bit of cut-and-paste after reading the reference and figuring out what was happening. When I connect an LED to PA1 or PA2, though, I still get nothing. I must be doing something wrong, but I'll be damned if I can figure it out. What am I missing?
