Author Topic: looking for arduino based multi boot cable for game boy advance, lost in space  (Read 7427 times)
Offline legacyTopic starter
hi guys
googling around i have found this useful article that shows you "how" you could upload an application into nintendo gameboy advanced. Unfortunately the article is pointing to a dead link about the arduino project, so i have opened this thread to ask if someone of you has saved the project and could share.
Thank you.
Online IanJ
  • Country: scotland
  • Full time EE & Youtuber
    • IanJohnston.com
Ian Johnston - Original designer of the PDVS2mini || Author of the free WinGPIB app.
Website - www.ianjohnston.com
YT Channel (electronics repairs & projects): www.youtube.com/user/IanScottJohnston, Twitter (X): https://twitter.com/IanSJohnston
yes, thank you!
very very useful information, i am toying with my GBA SP, pretty able to upload things in its internal 256Kbyte ram through the serial cable (made with an Arduino micro)  :D
Offline TeaNTronics
sorry for jumping this 1 month old post up back,
but i just want to tell i tired use this GBA Multi-booter too (about 6 months ago),
unfortunately, from what i've found, there is no tool for windows for this  :(
(except really old and outdated one that works with old printer port, and hard to work with, and also make problems  :palm: ).
So the only way you can run the tool is under linux or Mac OS.
anyway, i made to myself a small "dev-kit" of all necessary files needed for running this tool,
i'm attaching it.
it's including also instructions, some schematic, and 2 GBA Multi-boot tools:
- MSMCcable-1.01 (arduino sketch type)
- usb-gba-multiboot (arduino leonardo "frameware flashing" type, see: http://youtu.be/Zfmj_KPE_L4)
 (can be found under "Other Booting Tool" folder)
i tired to do it in Oracle VM VirtualBox with "PClinux", and it didn't work, its because the drivers in the latest linux version cannot support the MSMCcable-1.01 (which using old libraries),
so i guess the best way is to try it out with older linux versions (linux versions from 2004~2003, might work) and then try to install it.
i hope i've helped you with this
« Last Edit: November 13, 2014, 10:13:01 am by TeaNTronics »
Offline TeaNTronics
btw, i forgot to say, i dont have the BGA Link cable too,
you can order gameboy link cable for 1~3$ on ebay, cut it and rewire it to the arduino.
but i decide to do other thing, i've added serial port on my gameboy (using dupont 2.54mm connector)(see pictures)
so i can easily connect it to the arduino (with logic level converter of course).
i solder it to all 4 Serial pins on the gameboy link port.
its was really tight fit, i didn't had more room to use 5 pin connector. (for ground wire to the arduino)
so i'm using gameboy usb charge cable,
and i connect the ground the the arduino.
« Last Edit: November 12, 2014, 06:59:31 pm by TeaNTronics »
