Yeah I should have put this in the other ATTiny thread I had. This stuff is addictive. I've been making a model of this MCU/program, in the OpenOffice spreadsheet, it doesn't really do binary or hex. I've made clocked, full BJT ALU's in LTSpice before, so for real automation I might try some of this in LTS too. Before downloading some basic MCU sim program. Now I can't wait to make some 4 or 8bit MCU with all BJT's.
I'm using all NAND logic, so like open collector. With only using decimal 1,0 , 1-X=1 or 0 is an inverter, and the AND gate is X*Y=0 or 1. So I've made some register's, full 8-bit adders/ALU's, w/ inverted Carry flags, and 2's compliment were wanted, that matches the datasheet so far. And the Status SREG, for all the ALU flags.
For now, I'm just making copies/new GP reg's and ALU for each instruction of interest, like the compare w/ carry instructions.
So I can see in this blink program, how it made the millis function counter, using some compare commands and subtractions, and BRNE, to count down 255*165*14 ~590,000, and 255*82*7 ~146,000. I'll have to make a small # of cycles in the spreadsheet MCU, to see what it really does.
There's a bunch of POKE commands in the middle of the program, IDK much about the stack counter, or how all that will tie in to the "while" command, and the bitshift it does at the start, using compares, and more BRNE's. It starts witting numbers into the data SRAM too.
I expected the program to be shorter, I think I'm using the blink example in ArdIDE. Soon I'll have to try writing bare-metal Assembly for blink ON/OFF. The way they do it is probably fine, but IDK what all the rest of the middle code must be for yet.
#include <avr/io.h>
#include <util/delay.h>
int main(void)
DDRB = 1<<3; // port B3, ATtiny13a pin 2
PORTB = 0x0;
while (1)
PORTB = 1<<3; // port B3, ATtiny13a pin 2
_delay_ms(500);
PORTB = 0X0;
_delay_ms(250);
