Author Topic: Best platform to do robotics on?  (Read 3652 times)
Offline SuperMiguelTopic starter
« on: June 07, 2012, 08:15:34 pm »
Offline Erwin Ried
  • Country: no
Re: Best platform to do robotics on?
« Reply #1 on: June 07, 2012, 08:19:41 pm »
Does god exist? What's the meaning of life?  :-\
My website: http://ried.cl
Offline 8086
    • Circuitology - Electronics Assembly
« Reply #2 on: June 07, 2012, 08:36:08 pm »
For some reason I'm thinking Parallax Propeller
Couldn't really argue for it though  :P
« Reply #3 on: June 07, 2012, 08:44:02 pm »
i think most hobiest use arduino but they are doing simple stuff.. When you trying to get more into AI, what do ppl use??
Also im not taking something as high as ASIMO that uses a 3d cpu (http://www.digitalworldtokyo.com/index.php/digital_tokyo/articles/honda_creates_3d_cpu_to_power_super_asimo)
But something in between arduino and that 3d cpu... I know that most of the time ppl using arduino have to use interrupts to do multiple things at the same time, but u run out of them really quick...
« Last Edit: June 07, 2012, 08:46:33 pm by SuperMiguel »
Offline 8086
« Reply #4 on: June 07, 2012, 08:47:21 pm »
Look into Parallax Propeller - 8 concurrent processing cores, no interrupts
« Reply #5 on: June 07, 2012, 09:32:10 pm »
Nice! Parallax still using ASM or they work on C now?
Offline Erwin Ried
  • Country: no
« Reply #6 on: June 07, 2012, 10:19:11 pm »
I think there is no "best" platform for anything, it is a very broad question. What is the purpose of your robot? if requires high power I can think on a combination of low level things and a big cpu like an atom or arm.
In the past I built a robot with arduino and a netbook to do image processing from a camera and it worked OK, but as I said depends a lot on your objective.
Offline nctnico
« Reply #7 on: June 08, 2012, 12:23:02 pm »
Lego mindstorms comes to mind.
