I pretty much like the XMOS cores, appently unlike some
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
I do think they’re expensive for what you get though, and the point about the conceptual model not matching the implementation is double-edged. Yes, it means you can PAR several tasks onto one core, but you’re bringing back the complexity that the conceptual model hid away. Similarly, the moveable pointer idea - its clever, it’s well-implemented, but it’s different, and like anything wizardly, it is subtle and easy to anger…
OTOH I don’t think many people would implement an SDRAM controller in
software on a microcontroller, but you can, fairly easily, on an XMOS chip, and then vend that memory to other cores/tasks. Few microcontrollers provide time-stamped, clocked input/output of multi-bit ports, with SERDES available in hardware. If that sort of thing solves your problem, XMOS is your friend.
I don’t think they excel as general-purpose chips (too slow, too expensive, not a lot of RAM), but within the realm of problems they *are* applicable to, they are pretty much spot on. I’ve seen them a lot in audio processing for example, where hard real-time processing is crucial. Data acquisition is another.
Some of this ‘jitter is a myth’ talk seems a bit misguided to me - sure you can show negligible jitter for a single incoming signal by using ITCM, high interrupt priority, and it all works nicely. Now show me 8 different signals,
all being equally important, all being asynchronous to each other, and all needing that same latency response. A single-core CPU can perform one interrupt at a time, the benefit of the Xcore is that it can handle multiple signals/inputs at a guaranteed latency, without requiring a whole new MPU, clock, maybe external flash, and passives. Again, if you need that, it’s awesome.
Horses for courses, choose what works. Given the steady progression of low-end, low-cost FPGA parts, the XMOS advantage is being eroded IMHO, but all things pass - maybe XMOS will come out with something that can extend the line’s life, again, in its sphere of specialty.
