Author Topic: Beginners EPROM question  (Read 2082 times)
Offline veedub565Topic starter
« on: June 30, 2023, 03:32:18 pm »
I posted previously about getting some EPROM chips programmed, see thread here  https://www.eevblog.com/forum/microcontrollers/uvprom/msg4856921/#msg4856921 I was able to get them programmed professionally at a very reasonable price, but there is a problem and I thought it best to create a new thread.
There are 4 .bin files on 4 EPROM chips, and they contain the firmware for a piece of HP Test equipment (8341B). The original firmware was 1988, and the new .bin files are the updated 1992 firmware. It should just be a straight swap, program some EPROM's with the 1992 firmware and swap out the originals.... only it hasn't worked, the instrument won't boot at all and I had to put the old chips back in with the original firmware on.
I realise this isn't a test equipment or repair section of the forum, but my question is... would changing the .bin filename have any effect on the data programmed into the EPROM ?
original filenames were
8340BU34,TITMS27PC256-2Rev1992
8340BU35,TITMS27PC256-2Rev1992
8340BU36,TITMS27PC256-2Rev1992
8340BU37,TITMS27PC256-2Rev1992
And to make things a bit simpler I renamed them to
U34
U35
U36
U37
And I'm just wondering now if doing that has caused it not to work. I don't really know enough about programming EPROMS to know if it could or not.   :-//
**edit** just incase anyone notices the instrument is 8341b, and the .bin files say 8340b. It's the same firmware for both so thats not the problem.
« Last Edit: June 30, 2023, 03:35:09 pm by veedub565 »
Offline RoGeorge
Re: Beginners EPROM question
« Reply #1 on: June 30, 2023, 03:45:28 pm »
No.
The following users thanked this post: veedub565
« Reply #2 on: June 30, 2023, 03:56:38 pm »
Thanks
Offline jonsikul
  • Country: is
« Reply #3 on: July 09, 2024, 02:10:05 pm »
Did you ever get this to work?
Offline m k
« Reply #4 on: July 09, 2024, 06:58:37 pm »
If not then ROMs can be too slow.
1 in -1DC of original type indicates that access time is 100ns, one place states that 170ns is max.
Filenames have -2 in them, that indicates 200ns.
Manuals didn't help, or I was too fast.
Advance-Aneng-Appa-AVO-Beckman-Danbridge-Data Tech-Fluke-General Radio-H. W. Sullivan-Heathkit-HP-Kaise-Kyoritsu-Leeds & Northrup-Mastech-REO-Simpson-Sinclair-Tektronix-Tokyo Rikosha-Topward-Triplett-Tritron-YFE
« Reply #5 on: July 15, 2024, 04:29:51 pm »
Turns out there was a fault with the prommer that caused some of the data to be missing. I sent them back to be done again and it worked fine.
Offline m k
« Reply #6 on: July 15, 2024, 07:47:17 pm »
I had to make my own copier when Mini-Pro didn't read some weak bytes.
« Reply #7 on: July 19, 2024, 07:16:12 pm »
Well it was programming them from a file rather than copying from another EPROM. Not sure what the fault was, but the vendor rectified it anyway.
Offline m k
« Reply #8 on: July 20, 2024, 12:11:41 pm »
I've also had some ZIF lock problems with MiniPro.
Can't say for sure which side, some components have had symptoms, some don't, but all are old.
