Hi
I want to drive a PT2258 with a stm32f401 MCU. So far I wrote bare metal I2C driver, but I have some question about the bit format I'm going to use. In my project, I'm using only 2 channels (1 and 2) and I want to control them simultaneously using -10db step. My first question according to datasheet (attached pic2) for channel#1 -10dB attenuation the value should be 10010001(91H) and 81H respectively right! But, I saw online that people are using 90H and 80H respectively instead! Why?
The second question is related to how the bit format is sent to the PT2258. According to the datasheet(pic1), they say that I must send -10 dB followed by -1db. So, what if I want to send only -10dB then 0dB, is that going to work?
Thanks in advance
