File didn't attach the first time. I tried again here. Otherwise code is below:
oscillator_set
LDR R1,=OSCCTRL_OSC48MCTRL
LDR R0,=0x00070282 ;...1014:0x82 - On Demand | Enable Oscillator
STR R0,[R1] ;...1015:0x02 - 0010 div = 16MHz
;...1016:0x07 - 1024 Clock Cycle Startup (64us)
clock_gen_set_1
LDR R1,=GCLK_SYNCBUSY ;Load the SYNCBUSY Status
LDR R0,[R1]
LDR R2,=0x00000008 ;Look at bit 3
ANDS R0,R0,R2 ;If bit 3 is set,
BNE clock_gen_set_1 ;then check the SYNC status again
LDR R0,=0x00000306 ;else
LDR R1,=GCLK_GENCTRL1 ;Enable Generator 1
STR R0,[R1]
;Attach CAN0 to GCLK1
LDR R1,=GCLK_PCHCTRL26_CAN0
LDR R0,=0x000000C1
STR R0,[R1]
; CAN 0 Setup
can0_set
;Read the AHBMASK Register and modify it to enable CLK_CAN0_AHB
LDR R1,=MCLK_AHBMASK
LDR R0,[R1]
LDR R2,=0000'0000'0000'0000'0000'0001'0000'0000B
ORRS R0,R0,R2
STR R0,[R1]
;Enable Line 15 of the NVIC
LDR R1,=NVIC_ISER
LDR R0,=0000'0000'0000'0000'1000'0000'0000'0000B
STR R0,[R1]
;Enable CAN0 Register Configuration
LDR R1,=CAN0_CCCR
LDR R0,=0000'0000'0000'0000'0000'0000'0000'0011B
STR R0,[R1]
;Enable Bus Monitoring Mode
LDR R0,=0000'0000'0000'0000'0000'0000'0010'0011B
STR R0,[R1]
;Configure Quality of Service
LDR R1,=CAN0_MRCFG
STR R0,[R1]
;Configure Data Bit Timing and Prescaler
LDR R1,=CAN0_DBTP
LDR R0,=0000'0000'0000'0001'0000'0101'1000'0011B
STR R0,[R1]
;Configure Nominal Bit Timing and Prescaler
LDR R1,=CAN0_NBTP
LDR R0,=0000'0110'0000'0001'0000'1010'0000'0011B
STR R0,[R1]
;Configure Enabled CAN Interrupts
;XXXXXXXXXXXXXXXXX MAY NEED TO CHANGE THIS XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
LDR R1,=CAN0_IE
LDR R0,=0000'0000'0000'1000'0000'0000'0000'0000B
STR R0,[R1]
;Enable CAN Interrupt Line 0
LDR R1,=CAN0_ILE
LDR R0,=0000'0000'0000'0000'0000'0000'0000'0001B
STR R0,[R1]
;Standard Frame ID Filtering
;Reject remote frames and non-matching frames
LDR R1,=CAN0_GFC
LDR R0,=0000'0000'0000'0000'0000'0000'0011'1111B
STR R0,[R1]
;Number of filter elements: 2
;Filter List Start Address:
LDR R1,=CAN0_SIDFC
;Load the address of filter element 0
LDR R0,=can0_sf0
LDR R2,=0x20000000
SUBS R0,R0,R2
;Filter elements number specification: 2
LDR R2,=0000'0000'0000'0010'0000'0000'0000'0000B
ORRS R0,R0,R2
STR R0,[R1]
;Configure the Rx Buffer
LDR R1,=CAN0_RXBC
;Load the address of Rx Buffer 0
LDR R0,=can0_rxb0_0
LDR R2,=0x20000000 ;Start of RAM
SUBS R0,R0,R2
STR R0,[R1]
;Rx buffer is already set to 8-Byte data field
;Rx Buffer / FIFO Element Size Configuration
;LDR R1,=CAN0_RXESC
;LDR R0,=0000'0000'0000'0000'0000'0000'0000'0000B
;STR R0,[R1]
;Enable CAN0 and Lock Configuration Registers
LDR R1,=CAN0_CCCR
STR R0,[R1]
; Initialize RAM Variables
can0_filter_set
;Standard ID Filter Element 0
;[31:30] = Classic Filter => 10B
;[29:27] = Store into Rx Buffer (Ignore [31:30]) => 111B
;[26:16] = Frame ID: 0x123 => 001'0010'0011B
;[15:11] = Reserved => 0'0000B
;[10:9] = Store into an Rx Buffer => 00B
;[8:6] = Event pin => 000B
;[5:0] = Buffer Element Number: 0 => 00'0000B
LDR R0,=1011'1001'0010'0011'0000'0000'0000'0000B
LDR R1,=can0_sf0
STR R0,[R1]
; Beginning of MAIN Code
main
B main
; CAN0 Interrupt Routine
CAN0_Handler
__can0_handler
CPSID I
;Clear the interrupt flags
LDR R4,=CAN0_IR
LDR R3,=0000'0000'0000'1010'0000'0000'0000'0000B
STR R3,[R4]
;Clear the new data in buffer flags
LDR R4,=CAN0_NDAT1
LDR R3,=0xFFFFFFFF
STR R3,[R4]
;Read the messages from RAM
LDR R4,=my_RAM_variable
LDR R3,=0x0
STR R3,[R4]
LDR R7,=can0_rxb0_2
LDR R6,[R7]
LDR R5,=0x44332211
CMP R6,R5
BNE can0_handler_exit
LDR R3,=0xFFFFFFFF
STR R3,[R4]
can0_handler_exit
LDR R4,=CAN0_NDAT1
LDR R3,=0xFFFFFFFF
STR R3,[R4]
CPSIE I
BX LR
