Author Topic: ATmega8 stopped responding !  (Read 94 times)
Online Swaroop 21Topic starter
  • Country: in
« on: Today at 11:18:46 am »
I have a Atmega8 on a sensor board which contains a Accelerometer (MMA7361L). The ATmega8 doesn't have any crystal osc. and when I first soldered it, I burned the bootloader using a USBASP programmer for running on internal 8Mhz Freq. and uploaded a simple ADC sketch to print the X,Y,Z values. It worked fine but then the other day I was playing around with ATMega328PB and then I switched back to my sensor board with ATmega8, got in the tools section and I believe that when I burn the bootloader again it defaulted to its normal configuration i.e. External 16Mhz in the tools option and I didn't catch it which after that it stopped responding. I tried to burn the bootloader again and it said no target found. I haven't burnt any wrong bootloader. I used the MiniCORE boards manager. Is there a way to retrieve it without the external crystal or is there other problem which can't be fixed ? I don't think I killed it as I didn't misconnect anything. So what can be the reason for it to not detect neither burn a bootloader.
Offline mikerj
Re: ATmega8 stopped responding !
« Reply #1 on: Today at 12:28:55 pm »
After programming the fuses for an external clock you will need to apply a clock to the XTAL1 pin to enable any further programming.  It doesn't need to be a crystal or resonator, you could use  e.g. a 555 timer or use your Mega328 to supply a suitable temporary clock until you reset the fuses to the correct value.  You must set the programmer clock to 1/4 or less of the AVR clock frequency e.g. if you apply a 1 MHz clock, set the USBASP to 250kHz or lower.
  • Country: in
« Reply #2 on: Today at 01:14:39 pm »
I will give it a try. Thanks :)
Offline madires
  • A qualified hobbyist ;)
« Reply #3 on: Today at 01:21:27 pm »
If you have a programmer supporting the HV mode (parallel) you can use that alternatively.
