Ok, I pulled out real hardware (Atmega328p uno board) and tried it. I'm using the Arduino IDE found at
www.arduino.cc . I've never even looked at Protuse, so ask me no questions about that.
First off, the comma instead of a semi-colon comes out as a compile error for me, because it results in an attempt to redefine DDRC. Fix that. I don't know why your environment doesn't flag it.
Second, the compiler wasn't happy with void main(), so I changed it to int main() as the easiest solution.
Third, I discovered what is probably your core problem. When you use a main() function (instead of the setup/loop functions this IDE prefers), YOU become responsible for hardware initialization. It's not done for you! Calling init() at the top of main() should do it. init() sets up the system timers, which is important for correct delay times. Also, which is quite important in this case, it disconnects TX and RX from the UART used to program the board. Those happen to be the two pins on port D you're using for the LED outputs!
Last, my uploads failed at first. I'd only used 220 ohm resistors on the LED's, and that was enough of a load to disrupt the UART communications. I was too lazy to switch resistors, so I just unplugged the LED's during the upload, then plugged them back in.
After that, the code worked as written.
