Author Topic: ASF4: USB host function driver - how to access the device descriptor?  (Read 470 times)
Offline ubbutTopic starter
based on the examples provided by ASF4 I wrote my own compatible USB host function driver which is working fine.
Now, I would like to access the device descriptor from the function driver. I am however not sure how to do this properly.
The "install" function only gets a pointer to the interface descriptor it seems, not the start of the device descriptor.
And by the time this function gets called, the control buffer does not contain the device descriptor anymore
So my questions are:
from a host function driver, how can I access the device descriptor?
Related question:
How can I get the manufacturer and device strings?
thank you
