Author Topic: PIC18F97J60 code examples?  (Read 548 times)
Offline Red SquirrelTopic starter
« on: February 09, 2024, 10:15:46 pm »
Anyone familiar with this micro and have any good resources on coding for it?  There are some very brief sample assembly code in the datasheet but not enough to get a full understanding of how to code on it. not really looking for a full library just want to get enough examples so I know how to do basic things like initialize ports, use ports, send ethernet frames, receive ethernet frames, use i2c etc.
Ideally I would want to use C if possible but if this chip uses assembly then I've always been kinda tempted to brush up on that more. I've done very brief assembly before so understand it to a very small degree.
Offline DavidAlfa
Re: PIC18F97J60 code examples?
« Reply #1 on: February 09, 2024, 10:25:53 pm »
Offline woofy
    • Woofys Place
« Reply #2 on: February 09, 2024, 10:37:34 pm »
You can use mplabx/mcc to generate a tcp/ip stack for it.
