I know there are only 6 CFG registers, the 7th bit is for checking the PEC.
I can't really find any information in the datasheet that restricts the values in the CFG registers.
Byte 1 I am not changing, byte 2, 3, and 4 handle the discharge and interrupts for the cells, each bit is for a specific cell, byte 5 specifies the undervoltage, which defaults to 0, and byte 6 handles the overvoltage, which defaults to 0.
I don't see a problem with the values I am writing.
I plan on packing the functions once I get them working.
