After using a firmware with Silabs bootloader there is a problem with connection using Jovy PC Suite. Problem is caused by unoriginal bootloader, app try to get serial number from bootloader area and convert it to number what trows exception because data is rubbish, not a serial number.
So, I patched original .exe to use file sn.cfg as a external source of serial number. Without this file app will use hardcoded serial number for RE-8500 rev 1 with 5 TC. If you want to use with 3 TC version(serial number above JV85114013) or RE-7500 you should provide valid SN in config file. Licence files are not longer needed.
