Author Topic: I hate C printf format specifiers. Alternatives?  (Read 21635 times)
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
Re: I hate C printf format specifiers. Alternatives?
« Reply #50 on: September 03, 2015, 05:34:56 am »
This is because the location of const can cause confusion for many programmers.
https://en.wikipedia.org/wiki/Const_(computer_programming)#Pointers_and_references
Printf doesn't care where the format string comes from. You can generate multiple tables, for each language, of format strings which you can select. And printf just delivers. You can even have the user enter one at runtime. It is unfortunate printf can not dereference pointers, if it could it would be another bit more helpful displaying templated layouts.
« Last Edit: September 03, 2015, 05:37:48 am by Jeroen3 »
Offline westfw
« Reply #51 on: September 03, 2015, 05:49:21 am »
But not so optimal
I was thinking of mentioning that things like the "picture" based formatting have to be pretty expensive at runtime.  Something like ForTran can do a lot of the format processing at compile time because the feature is part of the language, but library-based functions as required by C are a lot harder to do.  The current printf() seems like it's a pretty reasonable compromise (although, I think printf() can be a lot "heavier" than some of the simple versions would lead you to believe.  I think I've seen printf implementations that end up calling malloc(), and running through the formatting twice for one reason or another.)
Offline legacy
« Reply #52 on: September 04, 2015, 10:03:28 am »
yet an other C++ alternative: C++format  :-+
Offline legacy
« Reply #53 on: September 04, 2015, 10:05:50 am »
the new strategy uses the variadic template method.
Offline nctnico
« Reply #54 on: September 04, 2015, 02:12:43 pm »
There is no requirement that the string passed to printf or fprintf is a constant string literal.
True but as I wrote before some compilers enforce that a format specifier is a string literal and not a pointer to a variable to prevent format string attacks.
