Author Topic: Simple Programmer for vintage Intel MCS-48 Microcontroller  (Read 17778 times)
Offline SaabFANTopic starter
Re: Simple Programmer for vintage Intel MCS-48 Microcontroller
« Reply #25 on: May 21, 2023, 02:24:19 pm »
No, I haven't done anything with this after I used it to reprogram the Microcontroller that lost its programming.
For anyone interested in getting a programmer like this, I would recommend this blog:
https://www.mattmillman.com/projects/hveprom-project/an-easy-to-build-mcs-48-8748-8749-8741-8742-8048-8049-programmer-reader/
Offline Kjelt
« Reply #26 on: May 21, 2023, 06:23:05 pm »
Long time ago I used those uCs , IIRC you could always place an external eprom since the address and databus are multiplexed. The uCs without internal memory are also easier to find and you can even use a parallel flash e2prom.
Online edavid
« Reply #27 on: May 21, 2023, 09:14:16 pm »
As mentioned earlier, this doesn't work for the 8041/8042, which is what this thread is about.
Offline Kjelt
« Reply #28 on: May 22, 2023, 07:36:07 am »
Ah yes I see I already said this in 2016   ;D
Old topic
