Yep, the old stm32duino.com forum started (RogerClark and Co.) early 2015 afaik, then it was moved under STM (perhaps end 2019). Therefore you may find various "cores" and various "bootloaders" versions there. The BluePill and perhaps a dozen of other board names originated there.
It started with Maple board and LibMaple core (plus some newer versions of it). The first company with the Maple (F103) board was company called LeafLabs.com (which finished with the Maple series in 2016) and the stm32duino.com took over its LibMaple core, adding a lot of fixes and enhancements to it in the next 4 years (I messed there a lot as well and it was a great fun!!). Also a new HAL based core version started.
At that early times there was none issue with fakes (the far-east vendors did not produce the F1xx clones at that time). Also at that time we discovered the STM32F103 (and higher) has got twice the advertised flash
In the following years the far-east producers managed the F1xx technology and the issues with BluePills started. Then the F3xx clones appeared, not sure F4xx clones are so spread, however.
The new stm32duino.com (since 2019 "owned/hosted" by the STM) moved to the HAL based STM32 core, but you will still find the older cores in the new forum.
