Author Topic: LCD Display Fault - Any Ideas what would cause this.  (Read 4110 times)
Offline ClintTopic starter
« on: December 30, 2013, 06:52:09 pm »
I have a repair in on a monitor but I have not seen an LCD do this before and was wondering if anyone would know what caused this.
Pic Attached.
Cheers
Clint
g33K5 L1k3 80085
Offline ZeroAviation
Re: LCD Display Fault - Any Ideas what would cause this.
« Reply #1 on: December 30, 2013, 07:01:22 pm »
I have seen this before. But I'm not smart enough to know what happened. :/
Offline PedroDaGr8
  • A sociable geek chemist
« Reply #2 on: December 30, 2013, 07:13:34 pm »
Delamination of the internal layers allowing the liquid crystal to spill from its chambers. This can be caused by one or more of the following: impact, temperature extremes, uv exposure (breaking down the adhesive) or , in the case of cheap ones, age.
Sent from my EVO using Tapatalk
« Last Edit: December 30, 2013, 09:35:27 pm by PedroDaGr8 »
The very existence of flamethrowers proves that some time, somewhere, someone said to themselves, "You know, I want to set those people over there on fire, but I'm just not close enough to get the job done." -George Carlin
Offline Rick Law
« Reply #3 on: December 30, 2013, 08:37:36 pm »
My daughter (when she was really young) poked her laptop's lcd screen hard by mistake it shows pretty colors under pressure.  She then tried to poke it harder and harder intentionally just to look at the pretty colors.  Eventually it turned into rainbow color like the picture you shown and at that point the screen was kaput.
Your LCD looks like it was under some mechanical stress - dropped, sat on, ran over by truck, whatever...
(She learned her lesson -  Daddy gave her a hard time for not thinking...  She still repeats it these days: "Before action, first come thought...")
Offline Mr Smiley
« Reply #4 on: December 30, 2013, 09:27:36 pm »
It's the eyes of a lost sole looking at you from the other side  :scared:
There is enough on this planet to sustain mans needs. There will never be enough on this planet to sustain mans greed.
Offline Stonent
« Reply #5 on: December 31, 2013, 01:13:14 am »
On the IT side we call that a cracked LCD. Not always a crack in the glass, but a stress fracture inside the LCD. (Going by the lines radiating within the rainbow)
Just heat by itself can cause the rainbow, but with the cracks, I say it got a bit too much pressure.
Online IanJ
  • Country: scotland
  • Full time EE & Youtuber
    • IanJohnston.com
« Reply #6 on: December 31, 2013, 11:15:17 am »
Twisting of the entire LCD due to bad mounting can also cause this. Might be fine for a while then suddenly fail.......
Ian.
Ian Johnston - Original designer of the PDVS2mini || Author of the free WinGPIB app.
Website - www.ianjohnston.com
YT Channel (electronics repairs & projects): www.youtube.com/user/IanScottJohnston, Twitter (X): https://twitter.com/IanSJohnston
Online PA0PBZ
« Reply #7 on: December 31, 2013, 12:34:34 pm »
Looks like it has been used for mammography.
Offline amyk
« Reply #8 on: December 31, 2013, 12:44:06 pm »
:-DD
Here's the effect responsible for the colours; the polarisers are there already since it's an LCD.
http://en.wikipedia.org/wiki/Photoelasticity
Offline BrianDagobah
  • I.T. Pro by day, Electronics hobbyist by night
    • Dagobah System
« Reply #9 on: December 31, 2013, 03:00:36 pm »
As others have said. I think it's a temperature thing. I lived in the desert for a stint, and I saw lots of LCDs die this way after being left inside the car in the summer. Meters, testers, even some old laptop screens.
Brian
Tech Blog: http://www.dagobah-system.com
G+ https://plus.google.com/102681862919770239777
I.T. Pro by day, Electronics hobbyist (not a very good one) by night.
« Reply #10 on: December 31, 2013, 09:04:43 pm »
Thanks all I replaced it today and it was stressed, its in a cnc milled enclosure that's too tight and the top corners of the display needed rounding off quite a bit :)
g33K5 L1k3 80085
Offline Rick Law
« Reply #11 on: January 01, 2014, 01:49:34 am »
Hmmm....  that would entirely depend on the patient, wouldn't you think?  I can imagine, with the right patient, being used for mammography could be a rather stimulating experience rather than a stressful one.
