Author Topic: Air105 / Air32F103 - New chinese arm chips  (Read 27724 times)
Online bingo600
Re: Air105 / Air32F103 - New chinese arm chips
« Reply #50 on: August 01, 2023, 08:00:36 pm »
@bingo600
Thank you, you are welcome!
The DAPLink firmware is for their
black board https://wiki.luatos.com/chips/air32f103/board.html
and tiny DAPLInk https://wiki.luatos.com/chips/air32f103/daplink.html
more details can be found at https://wiki.luatos.com/chips/air32f103/index.html
PCB of the black board:
https://cdn.openluat-luatcommunity.openluat.com/attachment/20220605164915340_AIR32CBT6.pdf
https://wiki.luatos.com/_static/bom/Air32F103.html
I haven't tried V2 but this should be the same as V1, what I know is it fixed the onboard LEDs and improved the download speed.
The source code can be found at https://gitee.com/openLuat/daplink
Pinout as a DAPLink
PB13: SWCLK
PB14: SWDIO
PB0: RESET
PA2: TX
PA3: RX
Thanx  :-+
I have the "Black board"
/Bingo
Offline 5U4GB
« Reply #51 on: August 05, 2023, 08:53:06 am »
What I don't get is they claim "compatible STM32 For Arduino". But the screenshots are showing Keil, and the AIR105 is clearly a completely different beast from the STM32F103.
It's a translation error, what they mean by "compatible" is that if you put them on the table next to each other they won't squabble or fight.
The following users thanked this post: harerod
Online bingo600
« Reply #52 on: August 16, 2023, 01:27:12 pm »
Have any of you tried the new daplinkv2 hexfile from the above link ??
I'm preparing for my first daplink setup, and don't want to be hit by "bugs" if/when making my first baby steps w. daplink.
/Bingo
Well i tried the AIR32F... daplink v2 hexfile , and it didn't work.
Everything looked "normal" I think ...
Well except for this message: 0000680 W Board ID 0001 is not recognized [mbed_board]
But program doesn't work after programming , not even if i disconnect the AIR daplink , and Powerreset the PY32F002 board
I loaded the AIR32F... daplink v1 hexfile , and it worked. ... AKA the "Blinky" began to blink on the target.
China DAPLINK - Works
$py32f0-template$ pyocd list
  #   Probe/Board              Unique ID      Target
  0   jixin.pro CMSIS-DAP_LU   LU_2022_8888   n/a
$py32f0-template$ make  flash
pyocd erase -t py32f002ax5 --chip --config ./Misc/pyocd.yaml
0000812 I Erasing chip... [eraser]
0001081 I Chip erase complete [eraser]
pyocd load ./Build/app.hex -t py32f002ax5 --config ./Misc/pyocd.yaml
0000820 I Loading $py32f0-template/Build/app.hex [load_cmd]
[==================================================] 100%
0002136 I Erased 4096 bytes (1 sector), programmed 1792 bytes (14 pages), skipped 0 bytes (0 pages) at 1.34 kB/s [loader]
$py32f0-template$
Air32 V2  - Program dowsn't work (run) on target after programming
  0   Arm Air32 CMSIS-DAP   000100011a5a5bb50000000001d2b777a5a5a5a597969908   n/a
      LuatOS                Air32 MINI DAPLink
0000684 W Board ID 0001 is not recognized [mbed_board]
0000750 I Erasing chip... [eraser]
0000913 I Chip erase complete [eraser]
0000740 I Loading $py32f0-template/Build/app.hex [load_cmd]
0001140 I Erased 4096 bytes (1 sector), programmed 1792 bytes (14 pages), skipped 0 bytes (0 pages) at 4.39 kB/s [loader]
$py32f0-template$
Air32 V1  - Works
  0   Arm Air32 CMSIS-DAP   070000011a5a5bb50000000001d2b777a5a5a5a597969908   ✖︎ stm32f103rb
      STMicroelectronics    NUCLEO-F103RB
$py32f0-template$
0000873 I Erasing chip... [eraser]
0001117 I Chip erase complete [eraser]
0000872 I Loading $py32f0-template/Build/app.hex [load_cmd]
0001776 I Erased 4096 bytes (1 sector), programmed 1792 bytes (14 pages), skipped 0 bytes (0 pages) at 1.95 kB/s [loader]
$py32f0-template$
Btw:
Daplink sees the v1 as a "stm board" , and the v2 as an Air32 board.
The v2 has this daplink message
Might have something to do with it .... But it still shows a erasing & programming  :scared:
Edit: I programmed the Air32 w. a jlink , specifying taget as : STM32F103CB
/Bingo
« Last Edit: August 16, 2023, 01:54:27 pm by bingo600 »
Offline Jack70
« Reply #53 on: October 10, 2023, 03:15:06 pm »
It seems like one of my AIR32F103 boards might be experiencing issues, though I'm not completely certain yet. The ST-Link loses its connection after around 10 seconds. I've tested the ST-Link with another STM32 board, and there are no problems there.
After 10s I get, Error: Unable to get core ID
I can read and program the Flash, but only within the first 10 seconds.
It's possible that it's not actually broken, and the issue might be due to something I've done.
I was trying to get spi3 working and was testing the remapping options, maybe that has broken something that can't be fixed with a full erase?
I know that remapping has some limitations on the air32, but I don't think they say something about losing connection after 10s, right?
Did someone else experience the same problem?
Edit: To be clear, I've used this board for a couple of months without any problems.
« Last Edit: October 10, 2023, 03:49:17 pm by Jack70 »
Offline IOsetting
  • Country: cn
« Reply #54 on: October 11, 2023, 12:50:26 am »
You recalled me a similar issue I met with STM32F407 some years ago. It later turns out the "WDG_SW" flag in Option Bytes were unchecked, which made the chip reset itself every several seconds.
Offline Jack70
« Reply #55 on: October 12, 2023, 10:28:31 am »
I will check it when I get back home, but the chip doesn't reset every 10 seconds; it runs stable. However, when connected to the ST-Link, it resets one time after 10 seconds and then runs stable for hours without any further resets.
I've tried this last night;
I had a brand new board, so I soldered some pins on the program header and tried it. Same problem - it resets once after +-10 seconds every time the st-link is connected.
Next, I tried a different programmer. I have a discovery board with an ST-Link, and that works just fine with the air32, no resets. So I thought it must be the programmer, but the programmer works just fine with an STM32H750, STM32FEB, etc.
The discovery board has an older firmware, so I tried the older firmware V2J40S7, but it made no difference.
I ordered two new ST-Links, a V2 and a V2.1, and I also ordered a DAP-link, maybe one of those will work normally.
Update:
Sometimes I'm just stupid, the AIR32F103 is already a DAP-link, and I have a second one, so I already have a working DAP-link. 😅
And I no longer suspect the AIR32F103. The CSK32F103 also had the same problem, but not all clones. I've checked 4 different clones and 3 original STMs, and only those two stopped working correctly last night.
This issue doesn't seem to be specific to AIR32. If I discover any interesting insights or if others encounter the same problem, I may start a new topic.
« Last Edit: October 12, 2023, 03:58:45 pm by Jack70 »
Offline DavidAlfaTopic starter
« Reply #56 on: October 13, 2023, 05:29:08 pm »
Are both STlinks using the same FW version?
Offline fanoush
« Reply #57 on: January 23, 2024, 02:12:09 pm »
1. AIR32F103x is an OEM product, the original type is Mega Hunt MH32F103x, you can still find MH32F103 chips on Taobao, they are the same.
I just spotted some boards having MH2103A CBT6 clone chips https://www.hlkpint.com/product6_1.php?lm=102 are these related to MH32F103x?
The datasheet says 216 MHz too.
Visible here https://ae01.alicdn.com/kf/A611cf33089f74830b00823becb2412c8A.jpg as part of STLINK V2 clone in this shop aliexpress.com/item/1005001621626894.html
EDIT https://www.hlkpint.com/kindeditor/attached/file/20230926/20230926121850_72307.pdf - migration from so called SXX32F103 with differences, clock multipliers ...
« Last Edit: January 23, 2024, 02:15:49 pm by fanoush »
Offline IOsetting
  • Country: cn
« Reply #58 on: January 23, 2024, 04:39:41 pm »
They are the the same chip.
The following users thanked this post: fanoush
Offline fanoush
« Reply #59 on: January 23, 2024, 08:08:02 pm »
Oh, great, thanks for confirmation. For some reason I like this usb dongle form factor of those ST Link V2 clones so will get a few with this chip :)
