One other annoyance (albeit minor) is that this chip has 2 C906 cores, which are good overall but were designed when the vector extension was not ratified yet. So it implements rvv 0.7.1, while rvv has been ratified and is 1.0 now, and recent binutils only support rvv 1.0.
Not if by "recent" you mean gcc 14.1, binutils 2.42 which support both RVV 1.0 and RVV 0.7.1 (under the name XTHeadVector).
You can choose which version you want using command line -march.
Even better, if you write RVV code using the C intrinsic function interface then the same source code can be compiled to either 0.7.1 or 1.0.
The only missing feature is auto-vectorisation doesn't support 0.7.1.
That bites as there are a number of actual chips on the market that have implemented rvv 0.7.1
Yes, literally billions of chips shipped according to THead, and on Linux-capable boards priced as low as $5 (such as the Duo, but also Pine64 ox64 and Sipeed M1s (BL808 chip) both of which also have 64 MB RAM.
0.7.1 is, obviously, not quite as good as 1.0, otherwise we wasted 2 1/2 years of committee time between those releases, but it's still a darned good vector ISA, and better than SIMD ISAs. Probably as good as Arm's SVE.
Meanwhile, what's the cheapest thing you can get SVE (spec published in 2016) or SVE2 (2019) in? No SBC that I know of -- not the RK3588, for example. High end phones only.
and they are now "let down" by the toolchains - you'd have to stick to a pretty old version, and find it. This has been discussed already a couple years ago (found discussions about it with Bruce)
Not a problem, I've had the relevant GCC/binutils snapshot at
https://github.com/brucehoult/riscv-gnu-toolchain even since the first C906 boards came out in 2021.
But now you can simply use current GCC.
From what I know, so far, very few actual, available chips implement rvv 1.0. There is the newer K230 which apparently does
K230 was the first, with the CanMV-K230 board released back in October. It's got two cores with the larger (1.6 GHz, dual issue C908) one supporting RVV 1.0. There are a couple of annoyances with it, the big one being that it's only got 0.5 GB RAM, the small one that the vendor OS runs Linux on the small (non RVV) core reserving the big core for microcontroller/realtime use. 3rd parties had figured out how to run Linux on the big core, with RVV enabled.
https://code.videolan.org/Courmisch/k230-boot/See also this excellent video which demos running RVV 1.0 code on the CanMV-K230:
youtube.com/watch?v=Ozj_xU0rSyY
The BananaPi BPI-F3 started getting delivered to customers in the last month. It has 8 dual-issue cores running at 1.6 GHz (and reportedly better than Arm A55 or SiFive U74) each with RVV 1.0. Also the price is good at $63 for a board with 2 GB RAM or $75 for a board with 4 GB RAM.
https://www.aliexpress.us/item/1005006921744822.htmlThe problem is I don't regard 4 GB as enough for an 8 core system. The SoC supports 16 GB RAM, which would be great, but boards with this are not (yet) available.
There are a couple of faster boards coming up using SiFive P550 cores. They will be comparable to RK3588 boards except they DON'T have RVV.
Late in the year the SG2380 boards with 16 SiFive P670 cores with RVV 1.0 should appear. Those are OoO with roughly Arm A78 performance, including around 2.5 GHz clock for the P cores. That should make a really usable PC, getting up into early i7 territory I think.
Of course, the chip is perfectly usable without the vector extension. Alternatively, one can either find a version of binutils that supports rvv 0.7.1 and just use 'as' for assembly code which uses rvv and still use a recent and mainline GCC/binutils for the rest. Or implement your own assembler.
Yup. Been doing that for years.
But now just use the current GCC version, 14.1.
