This is an off-topic reply but I'm hoping it helps save someone else:
I have been meaning to put NiMh batteries in the U1273Ax I showed on the previous page but have not been to IKEA yet.
I thought for sure it can work fine with some Alkalines for just a few weeks.
They where unused and from the same batch, expiry date December 2027
Looks like the second cell from the left in the attached picture shorted.
It smells burnt and is blackened, however all cells show quite nominal voltages from left to right both with a high and low impedance measurement:
1.497v 1.461v 1.485v 1.524v (I did check the batteries voltage before putting them in the meter and then they where all within a few mV).
So I expected something inside the meter had shorted (like a capacitor) but nothing looked burnt.
So I powered up the meter from a bench PSU and it draws a normal load and works fine.
So this is your call to find all Alkalines batteries in your possession and get rid of them, thank me later
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
In my case the only part that took damage was one of the battery series metal clips, so I got lucky.
I was going to measure something with the meter and it was totally dead: I guess the clip no longer made contact and that stopped the carnage...
