Having got the wave gen working nicely (DMA in double buffer mode, etc) I think the only viable way to reset the DMA buffer pointers (2) to the start of the buffers at the input waveform zero crossing is an ISR, enabled with CC1IE=1 in TIM1_DIER. That should produce an interrupt at the zero crossing.
I have played around with reading TIM1 CNT (which starts at zero at the input waveform zero crossing, and one of these
- poll CNT and if close to zero, reset the DMA pointers and set the byte count to the buf size
- poll CNT and use the value to calculate corresponding DMA pointer values and a corresponding buf size
The 1st method works but suffers from synchronicity issues. For example, at 400Hz, TIM1 CNT goes from 0 to ~6562 and I was looking at it being 0 to 65 which would give a good enough sync. But it is easy to miss this time slot if the loop is running at just the wrong speed, and it does need to be done quite often, say 10Hz, because the resolution of the frequency measurement (1/6500) together with the resolution of the wave gen (1/580, with 360 samples per cycle) when expressed in integers, produces a sufficient phase drift even during 1 second.
The 2nd method works but is really tacky, and you have to make sure that the DMA pointers correspond with the remaining byte count, otherwise you will lose some table values (the DMA circular mode uses byte count=0 to reset the pointers, not a comparison of a pointer with the last buffer address).
That's unless somebody has a great idea
One can improve the phase drift by using bigger integers, obviously, and with 36 samples per cycle the accuracy will be 10x better, but then I need a DAC filter which will produce a significant phase shift.
I am trying to work out how to set up the interrupt. The project already has TIM6 generating a 1kHz interrupt but the code is barely penetrable. There is a huge int handler in the HAL which steps through various interrupt sources and is obviously sub-optimal. I am not sure how the 32F4 interrupts are cleared; I have been doing embedded for 40+ years and normally you have to read a specific reg or toggle some bit to clear the interrupt; the 32F4 doesn't seem to need that.
UPDATE: I worked out how to get the interrupt to work, largely from this:
https://www.eng.auburn.edu/~nelson/courses/elec2220/slides/timers1.pdf.Took me ages to find that the CH1 capture event produces an interrupt via TIM1_CC_IRQHandler. Can't find any doc on this so I tried every "TIM1" vector until it hit the debugger.
Next thing was the stupid HAL handler. WTF is this total POS:
This section provides Timer IRQ handler function.
@endverbatim
* @brief This function handles TIM interrupts requests.
* @param htim TIM handle
* @retval None
void HAL_TIM_IRQHandler(TIM_HandleTypeDef *htim)
/* Capture compare 1 event */
if (__HAL_TIM_GET_FLAG(htim, TIM_FLAG_CC1) != RESET)
if (__HAL_TIM_GET_IT_SOURCE(htim, TIM_IT_CC1) != RESET)
__HAL_TIM_CLEAR_IT(htim, TIM_IT_CC1);
htim->Channel = HAL_TIM_ACTIVE_CHANNEL_1;
/* Input capture event */
if ((htim->Instance->CCMR1 & TIM_CCMR1_CC1S) != 0x00U)
#if (USE_HAL_TIM_REGISTER_CALLBACKS == 1)
htim->IC_CaptureCallback(htim);
#else
HAL_TIM_IC_CaptureCallback(htim);
#endif /* USE_HAL_TIM_REGISTER_CALLBACKS */
/* Output compare event */
else
htim->OC_DelayElapsedCallback(htim);
htim->PWM_PulseFinishedCallback(htim);
#else
HAL_TIM_OC_DelayElapsedCallback(htim);
HAL_TIM_PWM_PulseFinishedCallback(htim);
htim->Channel = HAL_TIM_ACTIVE_CHANNEL_CLEARED;
/* Capture compare 2 event */
if (__HAL_TIM_GET_FLAG(htim, TIM_FLAG_CC2) != RESET)
if (__HAL_TIM_GET_IT_SOURCE(htim, TIM_IT_CC2) != RESET)
__HAL_TIM_CLEAR_IT(htim, TIM_IT_CC2);
htim->Channel = HAL_TIM_ACTIVE_CHANNEL_2;
if ((htim->Instance->CCMR1 & TIM_CCMR1_CC2S) != 0x00U)
#else
else
#else
/* Capture compare 3 event */
if (__HAL_TIM_GET_FLAG(htim, TIM_FLAG_CC3) != RESET)
if (__HAL_TIM_GET_IT_SOURCE(htim, TIM_IT_CC3) != RESET)
__HAL_TIM_CLEAR_IT(htim, TIM_IT_CC3);
htim->Channel = HAL_TIM_ACTIVE_CHANNEL_3;
if ((htim->Instance->CCMR2 & TIM_CCMR2_CC3S) != 0x00U)
#else
else
#else
/* Capture compare 4 event */
if (__HAL_TIM_GET_FLAG(htim, TIM_FLAG_CC4) != RESET)
if (__HAL_TIM_GET_IT_SOURCE(htim, TIM_IT_CC4) != RESET)
__HAL_TIM_CLEAR_IT(htim, TIM_IT_CC4);
htim->Channel = HAL_TIM_ACTIVE_CHANNEL_4;
if ((htim->Instance->CCMR2 & TIM_CCMR2_CC4S) != 0x00U)
#else
else
#else
/* TIM Update event */
if (__HAL_TIM_GET_FLAG(htim, TIM_FLAG_UPDATE) != RESET)
if (__HAL_TIM_GET_IT_SOURCE(htim, TIM_IT_UPDATE) != RESET)
__HAL_TIM_CLEAR_IT(htim, TIM_IT_UPDATE);
htim->PeriodElapsedCallback(htim);
#else
HAL_TIM_PeriodElapsedCallback(htim);
/* TIM Break input event */
if (__HAL_TIM_GET_FLAG(htim, TIM_FLAG_BREAK) != RESET)
if (__HAL_TIM_GET_IT_SOURCE(htim, TIM_IT_BREAK) != RESET)
__HAL_TIM_CLEAR_IT(htim, TIM_IT_BREAK);
htim->BreakCallback(htim);
#else
HAL_TIMEx_BreakCallback(htim);
/* TIM Trigger detection event */
if (__HAL_TIM_GET_FLAG(htim, TIM_FLAG_TRIGGER) != RESET)
if (__HAL_TIM_GET_IT_SOURCE(htim, TIM_IT_TRIGGER) != RESET)
__HAL_TIM_CLEAR_IT(htim, TIM_IT_TRIGGER);
htim->TriggerCallback(htim);
#else
HAL_TIM_TriggerCallback(htim);
/* TIM commutation event */
if (__HAL_TIM_GET_FLAG(htim, TIM_FLAG_COM) != RESET)
if (__HAL_TIM_GET_IT_SOURCE(htim, TIM_IT_COM) != RESET)
__HAL_TIM_CLEAR_IT(htim, TIM_FLAG_COM);
htim->CommutationCallback(htim);
#else
HAL_TIMEx_CommutCallback(htim);
Surely, an int vector should just go to the ISR, which then clears the int source, and does whatever it needs doing? The above code seems to clear the source of the interrupt though... not sure without spending another hour following it around.
