> I don't know how to interpret that stack frame.
The first two rows are - as you've already used them - R0, R1, R2, R3, R12, LR, PC, xPSR, as they were stacked by the fault handler.
If you have FPU enabled, then next 4 rows are the FPU registers (or just space for them if lazy stacking is on, which probably is) and one more word is PFSCR. There may be an aligner, too, see CCR.STKALIGN.
The rest is what was at the stack at the moment when the fault happened.
This is a post-mortem status, nowhere it is said that it's useful, and also it may be full of red herrings, except that it's all you have. The svc instruction in snippet you posted causes the SVC exception, which should stack also the 0x08014610 as PC at that point, but that would be the on the bottom of stack only if FPU would not be used, so that's confusing. I'd have a look at the SVC handler, too, just for the fun. Yes I know that's the heart of the RTOS. I don't use RTOS and have exactly zero experience debugging it or debugging within it.
"Normally", with "simple errors", the fault happens so that PC points to the last "correct" offending instruction. Your PC points to 0x00208CEA. I don't know how that area behaves, probably traps, so it must've been a jump to that address immediately before, but we of course have no trace of where it jumped from. The problem with post-mortem analysis is, that you can't walk backwards (plus runaway program sometimes destroys evidence, too).
What is strange is also content of CFSR and HFSR registers you've given above, they are completely nonsense.
JW
