I am limited in connection by RF1 and RF2 connectors of the experimental board. It isn't possible to find their characteristic to select to itself the necessary 2 outputs for my sensor (ground and power). Can you help me ? I looked for information in board and microcontroller documentation. I entered into search the words signed at pinches of these connectors on the diagram of a board. The power supply range of my sensor is from 2.5V
to 5.5V (there is a built-in stabilizator) and supply current 35-60 ?A. I read this docs
http://www.ti.com/tool/msp-exp430fg4618. Thank you.
