Author Topic: won a 3458A on ebay!  (Read 3184 times)
Offline niner_007Topic starter
« on: May 18, 2018, 08:43:47 am »
It's in a pretty good condition, it was pulled from a working environment and sold for parts (or so the seller claimed). Self test all OK, will monitor it for a while to see if it's got any stability problems. It has the extended memory option but not 002. It has an HP frame, but it has had some work inside and some Agilent marked parts. The digital board is original.
Is there any way to purchase a new chassis to replace the old one, is Keysight selling it?
Cheers.
« Last Edit: May 19, 2018, 09:57:05 pm by niner_007 »
Offline ap
    • ab-precision
Re: won a 3458A on ebay!
« Reply #1 on: May 18, 2018, 09:05:34 am »
You can buy a new chassis (metal frame) but it is pretty expensive (500+; dont remember exactly). You can also buy the front panel and rear frame.
Metrology and test gear and other stuff: www.ab-precision.com
Offline TiN
  • Country: ua
    • xDevs.com
« Reply #2 on: May 18, 2018, 12:11:40 pm »
What's wrong with old chassis? Kit is available by P/N 03458-60100 - 700$USD tag.
Check if A3 is drifty, because that is $1400 deal there :)
Online Kleinstein
« Reply #3 on: May 18, 2018, 03:36:30 pm »
With an old unit one may also want to check the input EMI filter (moderate cost for replacement if needed) and the age of the battery buffered RAMs, especially the cal ram.
Offline e61_phil
« Reply #4 on: May 18, 2018, 06:59:03 pm »
If you have a GPIB adapter and python installed, I can give you my very small script which runs ACAL and reads the CAL factors to verify A3. It writes everything in an excel sheet.
I scheduled the script in the windows 7 scheduler. One nice side effect: Both 3458A ran freshly through ACAL when I come to work.
Edit: Unfortunately I switched off my measuring computer at work. Therefore, I can't send it before tuesday.
« Last Edit: May 18, 2018, 08:14:21 pm by e61_phil »
The following users thanked this post: niner_007
« Reply #5 on: May 18, 2018, 09:25:23 pm »
looks old that's all; yeah, even if I need to do that, it was still worth it :)
« Reply #6 on: May 18, 2018, 09:26:31 pm »
I do have both, please do, when able
« Reply #7 on: May 20, 2018, 08:29:09 am »
thank you <3
Offline e61_phil
« Reply #8 on: May 22, 2018, 10:48:49 am »
Hopefully nobody is disappointed. It's just so simple. ;)
I created a cal72.bat which calls python with this script. This batch file was called every morning from the windows scheduler.
The following users thanked this post: Pipelie, niner_007
Offline sokoloff
« Reply #9 on: May 22, 2018, 11:11:14 am »
I love when HP3458A isn't specific enough...  :-DD
Thanks for sharing the script!
