Author Topic: LM399 circuits from the datasheet, which one is better?  (Read 1841 times)
Offline dmmguyTopic starter
« on: February 06, 2022, 04:09:11 pm »
Hi everyone,
Both taken from the LM399 datasheet; which one is better?
Thanks
Offline KT88
Re: LM399 circuits from the datasheet, which one is better?
« Reply #1 on: February 06, 2022, 05:48:46 pm »
A salways: It depends...
The right one is optimized for portable (battery operated) use at the cost of higher noise (lower Iz) and drift (it takes some time for the heater to settle).
The following users thanked this post: dmmguy
Offline branadic
  • Sounds like noise
« Reply #2 on: February 06, 2022, 06:28:41 pm »
I would say: "None of them, use the bootstrapped solution instead."
-branadic-
Computers exist to solve problems that we wouldn't have without them. AI exists to answer questions, we wouldn't ask without it.
The following users thanked this post: bdunham7, dmmguy
Offline Gyro
« Reply #3 on: February 06, 2022, 06:57:25 pm »
That would be the second one then wouldn't it? The 200k resistor is just there to make sure it starts up.
Best Regards, Chris
Online dietert1
  • Country: br
    • CADT Homepage
« Reply #4 on: February 06, 2022, 07:01:01 pm »
Yes, the circuit shown in the lower right is the usual bootstrap circuit. The 200k resistor is for startup and the zener current comes in from the output via the 5k resistor. A standard value for that resistor would be rather 3 KOhm to pass about 1 mA from 10 V to 7 V.
Regards, Dieter
Online Andreas
« Reply #5 on: February 06, 2022, 07:16:45 pm »
Thats right. (but the 5K resistor should be more in the 3K range to get the specified 1mA current through the LM399)
For real precision cirquit I would improve the trimming scheme (like on other precision references like the AD587).
A pot with rather high T.C. should not be in series with usually better precision resistors.
And also the heater voltage should be stabilized for maximum stability if ppm level is needed.
With best regards
Andreas
Offline bdunham7
« Reply #6 on: February 06, 2022, 07:19:54 pm »
I've always been curious--is something like an LM7815 considered good enough for all purposes or is it ever worthwhile to use the 10V output with a comparator setup to stabilizer the heater input even more?
Online Andreas
« Reply #7 on: February 06, 2022, 09:08:59 pm »
Some results are in the LM399 thread.
e.g. here
https://www.eevblog.com/forum/metrology/lm399-based-10-v-reference/msg443181/#msg443181
so you can decide by yourself for some ppm/V how much stabilisation is needed for your application
with best regards
Andreas
