Author Topic: What are these boards from? Who can make use of them?  (Read 3163 times)
Online 1audioTopic starter
« on: November 26, 2018, 01:19:57 am »
In cleaning a pile of stuff in my shop I saw these boards I had picked up at some swap meet or???
They are out of some IET instrument. Probably an earlier version of a resistance standard. I really don't have use (I have a JRL and an ESI resistance standard box) but they should not go into e-waste, especially with all those relays.
« Last Edit: December 14, 2018, 06:02:38 am by 1audio »
Offline Vgkid
Re: What are these boards from? Who can make sue of them?
« Reply #1 on: November 26, 2018, 01:32:24 am »
Who made the resistors , they look interesting.
« Reply #2 on: November 27, 2018, 03:34:43 am »
They are large and seem to be wirewound. There are no mfr. markings just some numbers and a value. The whole PCB is conformally coated so its not easy to connect to the resistors. The inductors are all marked Dale. The resistors are in a binary sequence 1,2,4,8 to 128 it seems.
if you have the instrument and need one of these boards I'm sure IET would get a bundle for them. I have realized they aren't a lot of use for me.
Offline cdev
« Reply #3 on: December 08, 2018, 05:54:16 pm »
Are all the yellow boxes relays?
Offline alm
« Reply #4 on: December 08, 2018, 08:20:04 pm »
Looks like a bunch of inductors / resistors switched by relays to me. Given the binary sequence, likely a variable resistor / inductor, which might be part of an automated bridge. GenRad (and by extension IET) made quite a few of those. This is just speculation; I've never seen the insides of such a bridge.
Offline Edwin G. Pettis
  • The plural of anecdote is not data.
« Reply #5 on: December 09, 2018, 07:07:21 pm »
Sorry, the resolution is insufficient to 'read' any part numbers, can you do a zoom in on some of them or just write the numbers down.  Even the board numbers are a bit difficult to make out.  Without more information I can't make any identifications.
Offline umkumiut
« Reply #6 on: December 10, 2018, 10:57:14 am »
They look like Aromat (Panasonic) ones.
« Reply #7 on: December 14, 2018, 06:02:16 am »
A few more details.
The boards are conformally coated and the connectors are eurocard-esque but use hollow sockets, 200 ea, and must be really expensive.
Boards have part numbers and serial numbers Common is a serial number starting with 85350XXX  Pt. No. 002(6404120 1) or similar.
!) Aromat DS2E-ML2-DC24V relays
2) Resistor markings. They all look like wirewound but I can be fooled . Marked for example:
14193
8521 CN
RWR78
S3201
   FR
3) Inductors are Dale marked TE4 or TE5
If someone can make use of these please contact me.
Re: What are these boards from? Who can make use of them?
« Reply #8 on: December 14, 2018, 06:03:07 pm »
The resistor is a MIL-PRF-39007 style RWR78, date code is 8521 CN, the part number 14193 is a house number, these are power resistors, not precision.  They are 1% and come in a variety of TCRs, may have been made by Dale as well.  You can find general data sheets on the RWR78 on line, they have commercial versions as well.
The following users thanked this post: alm
