It really depends on the changes you measure. A resistor, depending on the type of product, can be rated with a TC of say 200ppm/K, maybe even more. Standard metal film usually are 50ppm/K.
I have certainly seen that effect with 6.5 digit meters, even self-heating through the test currect of the meter. If you indicate the changes you see, one could better assess this.
