Yes, the circuit shown in the lower right is the usual bootstrap circuit. The 200k resistor is for startup and the zener current comes in from the output via the 5k resistor. A standard value for that resistor would be rather 3 KOhm to pass about 1 mA from 10 V to 7 V.
Regards, Dieter
