Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Metrology
Diff-amp 1GHz
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Diff-amp 1GHz (Read 4867 times)
luky315
Regular Contributor
Country:
Diff-amp 1GHz
on:
August 30, 2023, 09:52:39 pm »
I am looking for an Differential Amplifier with the lowest possible noise to amplify a small diff. signal (50R impedance, 1mVpp, 10MHz - 1GHz) at least 5x (10x prefered)
I found the LTC6401-20 which looks like a nice fit, but the noise is a bit to high (2.1nV/√Hz)
Can someone suggest a low noise part for this job?
Logged
ycui7
Contributor
Country:
Re: Diff-amp 1GHz
Reply #1 on:
August 30, 2023, 10:28:41 pm »
how about
https://www.ti.com/lit/ds/symlink/lmh5401.pdf
Logged
www.specialtycircuits.com
luky315
Regular Contributor
Country:
Re: Diff-amp 1GHz
Reply #2 on:
August 31, 2023, 10:35:50 am »
Thanks! TI has some very interesting parts... LMH6554 looks also nice, it is slower, but with less noise.
ISL55210 is also surprisingly good according to the datasheet, I have never used Intersil / Renesas analog parts, maybee it is worth a try
Logged
David Hess
Super Contributor
Country:
DavidH
Re: Diff-amp 1GHz
Reply #3 on:
September 01, 2023, 03:36:26 pm »
With only 1 millivolt peak-to-peak, you can use a two transistor differential amplifier with a pair of NPN RF transistors and no emitter series resistance. Noise is set by the tail current, so get a couple of medium power ones and operate them at higher current. Gain is proportional to tail current and collector load resistance. Noise will be lower and speed will be higher than any integrated solution.
Logged
ch_scr
eplpwr
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Metrology
Diff-amp 1GHz
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
