Here is the plan: 5V (usb) input-> isolated dc/dc converter -> linear voltage regulator with 1mA current limit -> LT1021DCN8-7 -> over voltage/reverse voltage protection diodes-> glass fuse -> binding post output.
Parallel to the protection diodes a 10uf tantalum in series with a 4,7 Ohm resistor and obviously some capacitance around the linear regulator.
The above copied 3 or 5 times in one enclosure with one shared input, with the isolated converters I can connect the reference outputs in series for
higher voltage output.
Sounds like a reasonable plan?
Also and perhaps in the same enclosure I would like to build some sort of a resistance standard, 0R1,0R9,9R,90R,900R, in series with dual binding post in between so the individual resistors can be measured with 4 way connections but also multiple in series, could also act as a current shunt.
and 10K,10k (matched to 1ppm) and 100K,100K (matched to 1ppm) also with dual binding post for 4 way connection, could also act as single sides of a wheatstone bridge.
These resistors I already own, but also want to include higher values (1M and 10M) but not sure what resistors and connections to use?
While we are at it also add some capacitors to be calibrated, 100nF, 1uF, 10,uf ? Wima MKP10 good enough?
Suggestions much appreciated, parts will be ordered this week.
So the question changes a bit, Who can measure 6,95V, a large range of resistor values and some capacitors, to within 100ppm?
Having this device measured by several people probably isn't a bad idea and that way others can get some use-full data from it as well.
