I don't think you need a guard trace around the inverting opamp input, because that is relatively low impedance - it would needlessly complicate the layout. You absolutely need one around the + input though.
Re: protection, maybe a low voltage GDT right at the input, followed by a resistor to limit the current to whatever the opamp protection diodes can tolerate. Note that the LTC1052 lacks such a specification, unlike more modern opamps. It even warns you to never exceed the supply voltages or risk "destructive latchup". As I understand the wording in the datasheet, protection diodes (internal or external) are not enough to prevent this.
