I hope nobody minds me hijacking this thread.
So the Wavetek 4600 arrived today and I'm afraid the manual would be super useful. I didn't pay much, probably the low thermal binding posts + 11 S102 Vishay resistors are worth more, but I would rather have the amplifier.
The unit consists of a small transformer - I'm guessing for linear supplies for the precision section and a big switching supply that seems to be described in the US4910653 patent, taking mains on the input, via bridge rectifier, caps and other typical bits and bobs through two IXTH12N50A with gates driven by small inductors (it looks so), these transistors drive this strange dual transformer arrangement (described in the patent) and the secondary side is pretty much just four USD945 and a lot of caps. That is the main board of this PSU, auxillary board has the control for both sides and AFAIR some form of feedback.
This switcher produces high amp +- 7.5V that goes via bus bars to the power output stage. Here it looks like a NPN/PNP push-pull output, with 9 x MJE15028 (NPN), 3 x BD139 (NPN), 9 x MJE15029 (PNP) , 3 x BD140 (PNP), lonely OP27 and 18 W21 R47 5% resistors (I guess to balance the currents) + misc components. This is controlled via IDC cable from the precision section. Busbar output from this stage enters the precision section of the device, goes through a precision selected shunt resistor and via relay ends on the output binding posts.
The precision board is complex, full of analog wizardry, precision resistors and opamps + some digital stuff related to the remote control from the 4800 series calibrator (i.e. non-solo mode).
The problem is that there is no output. After connecting a valid load (either L&N 4385 shunts or a DMM on amps) it allows to enable the output (no Overdrive), no other errors on the front panel, but the output isn't what it should be (1A/V). However, there is some faint transimpedance action:
Volts | Amps |
0.19 V | 0.0 mA |
1.0 V | 1.15 mA |
5.0 V | 6.90 mA |
10.0 V | 14.20 mA |
and Overdrive cut-off at around 12.5V. The gain is ~1000x less than it should be.
The switcher produces this +-7.5V voltage, I don't know if this is correct but seems sensible. Next week I'll try loading these rails to 11A with a DC load. The unit is full of the nasty old drop-shaped tantalums, but I didn't find any obvious shorts or explosions. The precision feedback control board will require complex study.
My first suspect is the power output stage. It runs extremely hot, too hot to touch in a mater of minutes - without even producing a single amp (and the fan running). I know this is bipolar, but still doesn't feel right. And the whole unit consumes the nameplate power (~200W) constantly. One would guess that Overtemperature/Overload indicator would work or any of a dozen of fuses inside would be blown, but sadly no
If anyone has any hints that would be more than welcome. Next week I can post more detailed photos from the internals.
