Here is my stuff that dieter1 will bring:
*Dual (lt1021-dmh10) 10V voltage reference.
*Resistor box 1, 100R, 1K, 10K, 99k7 (all ESI resistors) cable included for force connection, the 99k7 is a bit unknown my (low-res..) meters are a bit divided over that one although the resistor is very stable (not damaged just a oddball value)
*Resistor box 2, 1M, 9M, 90M 0,1%
Also included are the three papers to write down your readings, I expect them to be full at the end of the day.
Please do not exceed maximum ratings.
