Hello Voltnuts
this review is a bit late after MM2022 Stuttgart. Nobody got time anymore, even so pensioners
André gave his intro to around 35 people and showed all his amasing previos projects.
Dont´d know when he sleeps!
He also managed to have a live session.
Among us older also lot of young international people showed up.
There were quite some colored and very interesting lectures.
Noise on high stability Oscillators - Dr. W. Griebel
Automated Measurements - A. van der Meulen
My Ring comparison results - W. Vongehr
Three corner hat measurements - W. Oelschlegel
Horizon EDA - Lukas K.
Visit Taiwan Cal Lab - TIN
Home made Calibrator - J. Krummsdorf
Super PulsCaps - R. Schmitz
Measuring smal pulses M. von Rosenberg
Selecting LM 399 P. Baus
Measurement Technology for the extreme Demands E. Schreiber
Highlight was Prof. Dr. Klaus von Klitzing talking about Quantum Hall Effect.
At the end every body could hold his Novel Prize medal with one exception -
nobody has to left the room before he got the medal back
During lunch( finger food and drinks ) he gave a nice discussion before he left.
After then there were busy measurements with all sort of Instruments, References and Resistors.
Sorry for no more pictures. Only few space on the table were left empty.
André provided a 3458 witch was calibrated (+- 5.5ppm ) a few days before the event.
So everybody could compare his own Instrument or Reference to this value.
Wulf has done the 3 corner hat measurements to find the lowest noise performer
among F7000, W7000, F732A/B.
Now hopefully every body knows his " Volt - Ohm" respectively Referenc
with correction factor seen on the cal paper of 3458 Instrument.
André also showed the Ring comparison results done from may to august.
For me the values varied in an small acceptable range, except one.
This was also a big success and now a good starting point for the next round.
A great THANK YOU André and to all the contributors.
Hope to see you all healthy on the 4. MM Stuttgart also the this year missing people too.
Sorry, no pictures from all contributor taken.
Sprock
