Just brought home a 2703, after a 300+ mile round trip to collect it. Pretty clean inside, with just the right hand plastic handle extension broken off. On power up, it first comes up with "Hello" on the voltage display, then "3d" on the frequency display. Then "bad", voltage and "data", frequency. No diags in the manual, but any info as to what this means ?. Can copy the eprom, if anyone needs it, eprom label says: "2703 VD 1-10-89"...
Thanks,
Chris
