Author Topic: Ultra Precision Reference LTZ1000  (Read 1387375 times)
Offline TiN
  • Country: ua
    • xDevs.com
Re: Ultra Precision Reference LTZ1000
« Reply #2300 on: June 19, 2018, 08:50:15 am »
Based on eBay listing photos, sadly 15K/1K is used with CH chip.
The following users thanked this post: Dr. Frank, borghese
« Reply #2301 on: June 19, 2018, 11:51:55 am »
I think the problem may be that your price is a little bit too high. You can buy original 3458A A9 ref boards for less quite often on ebay and they use the LTZ1000ACH.
Also on a $350 ticket item a description that includes a phrase like "The chip has been tested and appears to be working correctly in circuit, but has not been burned in for even better stability." doesn't exactly inspire confidence. Someone who's going to fork out $350 wants a guarantee that the board is working and meets specifications, which for an item like the A9 board includes a drift test over at least several months. That is the value add and that is what justifies a price that is significantly above the BOM cost.
The following users thanked this post: TiN, borghese
Offline doktor pyta
« Reply #2302 on: June 19, 2018, 02:34:22 pm »
From ebay item's description:
'LTZ1000 heat compensated chip standard (which often goes bad)'
prove it
Online Kleinstein
« Reply #2303 on: June 19, 2018, 05:04:50 pm »
I would not expect a lot of failing LTZ ref modules in the 3458. They are supposed to be well tested and burned in. So the bad ones with excessive drift or significant popcorn noise (which might often come together) should be sorted out. There still seem to be rare cases with HP refs. to show popcorn noise, but I am afraid the chances are higher with the untested replacement boards.
Offline martinr33
« Reply #2304 on: June 19, 2018, 05:52:08 pm »
I think that there would be some interest in the bare board from this group. That might be a way to recover your investment. You might also find some buyers for the completed board, at a price that lets you recover the parts cost.
Thanks for doing this, I know that it isn't meeting your expectations but it is nice to have this piece of engineering done.
Offline VK5RC
« Reply #2305 on: July 02, 2018, 08:05:44 am »
If I recall correctly - somewhere in this post - somebody gave mentioned a good quality socket that could be used to temporarily fit an LTZ - to try and sort some 'good ones' without a full board each.
Does any one recall the detail of the socket/source etc or did I imagine it?  :-//
Offline SvanGool
« Reply #2306 on: July 02, 2018, 09:07:07 am »
# Don't hurry, the past will wait. #
Offline VK5RC
« Reply #2307 on: July 02, 2018, 09:55:29 am »
Offline branadic
  • Sounds like noise
« Reply #2308 on: September 16, 2018, 12:33:44 pm »
Since I received a few vintage LTZ1000 samples from lowimpedance and need some boards for comparison I decided to use the design of Dr. Frank. I modified his design to fit into a Hammond 1455C1201 case and added LT1763 (SO8) voltage regulator, giving 12V. This is how it currently looks like. The 3 blocks to the right indicate the place for Pomona 3770 binding posts.
-branadic-
Computers exist to solve problems that we wouldn't have without them. AI exists to answer questions, we wouldn't ask without it.
The following users thanked this post: lowimpedance, VK5RC, msliva, 2N3055
Offline Haasje93
« Reply #2309 on: September 18, 2018, 10:31:26 am »
It looks really nice! :-+
Offline Dr. Frank
« Reply #2310 on: September 18, 2018, 12:18:52 pm »
Hello,
the loose power supply GND cable must NOT be connected to the negative reference star point, but instead to the jack farther right.
I'd recommend to separate the power supply thermally and shileding-wise.
I see no basic deviation to my LTZ design, so far, so the rest is ok.
Frank
The following users thanked this post: msliva
Offline Andreas
« Reply #2311 on: September 18, 2018, 04:38:48 pm »
+1 for the thermal isolation between LT1763 and LTZ.
(thats why I will do a re-design of my B-revision)
In your case it might be less urgent if you have a stabilized external supply instead of battery.
with best regards
Andreas
Offline branadic
  • Sounds like noise
« Reply #2312 on: September 18, 2018, 07:37:50 pm »
Thanks for the feedback. Changed the loose wire to JP2, added a thermal slot between regulator and reference ciruit and changed two MKS 100nF to MKP2 100nF. Attached the almost final state of the board.
-branadic-
« Last Edit: September 19, 2018, 07:07:15 pm by branadic »
Offline branadic
  • Sounds like noise
« Reply #2313 on: September 19, 2018, 06:01:10 pm »
I will order some boards within the next days. Someone out there who wants a few boards of this layout as well?
-branadic-
Offline BradC
« Reply #2314 on: September 19, 2018, 11:39:06 pm »
-branadic-
I'll put my hand up for one please.
Offline GregDunn
« Reply #2315 on: September 20, 2018, 12:57:51 am »
Are you selling boards only, or boards with the LTZ1000?
Offline branadic
  • Sounds like noise
« Reply #2316 on: September 20, 2018, 05:57:16 am »
Boards only...
For orders please write me a short pm with how many boards you need. I will close this offering by the end of next week and order the boards in the necessary quantities.
-branadic-
The following users thanked this post: eplpwr
Offline branadic
  • Sounds like noise
« Reply #2317 on: September 20, 2018, 04:53:04 pm »
Wow, didn't expect such a response. I think I will order at Elecrow and pcb cost will be in the order of $2 per board or less depending on the final quantity plus shipping cost (Airmail) plus shipping to you guys (simple envelope to keep cost down). Thus I changed the outer form to a rectangle of size 120 x 50mm². PCB color will be black with immersion gold, single layer board.
Attached is the final schematic.
Please send me an official email adress with the PN too. Thanks.
-branadic-
« Last Edit: December 06, 2023, 07:35:29 pm by branadic »
The following users thanked this post: MiDi
Online Kleinstein
« Reply #2318 on: September 20, 2018, 05:18:31 pm »
The pot for gain adjustment in the final stage is a little odd. Normally one avoids using such low ohms pots, as the wiper contact may not be that reliable.  The more normal way is to have something like 10-100 Ohms in parallel to a 10 K pot with 5-100 K in series.
Offline branadic
  • Sounds like noise
« Reply #2319 on: September 20, 2018, 05:51:24 pm »
Since this board is working for Frank and since I had the chance to measure one of his reference boards I wouldn't complain ;)
-branadic-
Offline seec
  • Country: ru
Offline Andreas
« Reply #2321 on: September 21, 2018, 12:27:27 pm »
Does not look genuine to me
- LT-logo is missing
- printing is not correctly aligned to Pin 8 marker.
So in best case it is refurbished and re-marked.
see also:
http://volt-nuts.febo.narkive.com/FIfiYHU5/ltz1000ach-and-ltz1000ch-in-china
with best regards
Andreas
The following users thanked this post: seec
Offline try
  • Metrology from waste
« Reply #2322 on: September 21, 2018, 01:04:42 pm »
Hello Kleinstein,
as far as I know every wiper contact can fail. Is there a particular issue with low ohm pots?
Obviously your proposal does not fit Frank's trimming scheme where he is basically trimming in series needing an option for a low ohm variation at the end of the trimming chain.
Could you propose a complete trimming scheme for the divider regardless of the layout available on the PCB?
« Last Edit: September 21, 2018, 01:16:24 pm by try »
Offline branadic
  • Sounds like noise
« Reply #2323 on: September 21, 2018, 08:13:59 pm »
One week left to sign up for the board. Currently there are 45 boards on the order list. Currently there are 130 boards on the order list.
6x branadic
3x SvanGool
3x BradC
4x eplpwr
3x Sprock
2x FredTW
2x Haasje93
1x retroware
2x dhillman
5x try
2x flittle
10x bck
5x F64098
2x RandallMcRee
10x MiDi
5x e61_phil
2x Le_Bassiste
5x quarks
2x Macbeth (3)
5x meandeev
5x martinr33 (10/20)
3x Hermann W
3x mikron
2x Harfner
3x pansku
2x Carrington
2x mweymarn
3x Vbemultiplier
6x vmiceli
5x ap
3x sixtimesseven
2x AlfBaz
5x FriedLogic
2x guenthert (need email address)
2x Vgkid
3x borghese
-branadic-
« Last Edit: September 29, 2018, 04:50:21 pm by branadic »
The following users thanked this post: bck, sixtimesseven
Offline Echo88
« Reply #2324 on: September 22, 2018, 10:42:27 pm »
My attempt:
LTZ1000-PCB Designed by Dr Frank and
LT1763-Low-Noise-Supply designed by Cellularmitosis
Both PCBs are made available as OSHW by Cellularmitosis (big thanks  :-+ ) and can be bought here or via any other pcb-manufacturer with the gerber-files:
https://oshpark.com/shared_projects/dGYcQAgn LTZ-Board
https://oshpark.com/shared_projects/uVr4yDgz LT1763-Board
Why i did it that way:
LTZ1000 is directly buffered via LTC1052 since i dont use the 7->10V-function for the references at the moment,
LTZ1000 protected from airflow by green lemonjuice-cap,
an EMI-Filter BNX002-01 is used at the power supply input https://www.murata.com/en-eu/api/pdfdownloadapi?cate=luNoiseSupprFilteBlockType&partno=BNX002-01,
a double sided copper-clad-board at the pomona-jacks should equalize thermal differences pretty well,
the LT1763 is located further from the LTZ1000-PCB, so it doesnt affect it by temperature variation due to varying input voltage,
TEKO 393-case is afterwards stuffed again with paper towel shreds to reduce airflow,
Resistors by Edwin Pettis
« Last Edit: September 22, 2018, 10:45:57 pm by Echo88 »
The following users thanked this post: cellularmitosis, chuckb, guenthert, MiDi
