Author Topic: Ultra Low Noise Reference 2DW232, 2DW233, 2DW23x  (Read 262598 times)
Offline Andreas
Re: Ultra Low Noise Reference 2DW232, 2DW233, 2DW23x
« Reply #175 on: November 18, 2016, 05:52:48 am »
Thank you for preparing this translation, but I think the listed pinout is incorrect.  For the devices I received from VintageNut, pins 1 and 2 are anodes, and pin 3 is the common cathode.
Hello,
The translation corresponds to the picture from the datasheet. (first page on the thread).
Do you really measure 5.6 instead of 0.7V on the ground referenced diode when using a pull-up resistor?
With best regards
Andreas
Online edavid
« Reply #176 on: November 18, 2016, 05:57:26 am »
Yes, that is also incorrect (or doesn't match the parts I received).  Very odd.
Sorry, I don't understand this question.
Offline Andreas
« Reply #177 on: November 18, 2016, 06:27:25 am »
if you take the cirquit from Alex:
https://www.eevblog.com/forum/metrology/ultra-low-noise-reference-2dw232-2dw233-2dw23x/msg1068444/#msg1068444
e.g. with 15V supply and resistor = 1K
what voltage do you measure between Pin 3 (case of zener) and ground?
With best regards
Andreas
Offline Alex Nikitin
  • Femtoampnut and Tapehead.
    • A.N.T. Audio
« Reply #178 on: November 18, 2016, 08:51:06 am »
I've measured (by a multimeter diode test only so far) one of the devices I've received and it is indeed a common cathode configuration, as shown on the attached diagram.
Cheers
Alex
Offline Andreas
« Reply #179 on: November 18, 2016, 10:35:23 am »
So its more difficult to measure the chip temperature since the forward diode is not referred to GND.
With best regards
Andreas
    • A.N.T. Audio
« Reply #180 on: November 18, 2016, 10:52:06 am »
With best regards
Andreas
It will be easy in a negative reference configuration though ;) . In a positive reference the diode can still be used easily for a temperature stabilization with an external heater.
Cheers
Alex
    • A.N.T. Audio
« Reply #181 on: November 18, 2016, 01:45:05 pm »
I'm running a measurement on the first sample right now. The circuit is attached. R1 is actually a resistor decade set at 515 Ohm, that is a reasonably stable point. The zener is connected through an IC socket, the 10V source is my JVR reference, so it is quite stable, C1 is a Mylar film capacitor. Right now I'm using the 34465A. I might leave it running over the weekend with 3558A though.
Cheers
Alex
P.S. - first impressions are ... interesting. Very little random noise but the device is (relatively) sensitive to temperature variations and air movements. I suspect that it can only be useful with a good temperature stabilizing loop. With ~7.5mA and 6 Volts the dissipation is quite high and so is self-heating. As a result, any air movements produce noticeable voltage shifts (few ppm even with a good foam envelope around the device). The dynamic resistance at 7.5mA is about 13-14 Ohm. We'll see how it performs over the weekend.
« Last Edit: November 18, 2016, 03:16:05 pm by Alex Nikitin »
Online edavid
« Reply #182 on: November 18, 2016, 04:20:50 pm »
Is your device a 2DW232 or 2DW233?  I know zlymex told us not to pay much attention to the nominal current, but...
Offline zlymexTopic starter
  • Country: cn
« Reply #183 on: November 18, 2016, 05:02:15 pm »
..... With ~7.5mA and 6 Volts the dissipation is quite high and so is self-heating. As a result, any air movements produce noticeable voltage shifts (few ppm even with a good foam envelope around the device). ......
The foam should be in touch with the case and legs, leaving as small gaps as possible. I just use tissues.
    • A.N.T. Audio
« Reply #184 on: November 18, 2016, 05:56:33 pm »
2DW232
Cheers
Alex
    • A.N.T. Audio
« Reply #185 on: November 18, 2016, 07:43:29 pm »
Here is a one hour run result from this afternoon, the temperature probe is inside the foam enclosure but not touching the zener.
Cheers
Alex
« Last Edit: November 18, 2016, 07:45:53 pm by Alex Nikitin »
The following users thanked this post: evb149
Offline Kleinstein
« Reply #186 on: November 18, 2016, 07:59:38 pm »
This does not look good at all. I might need a better adjustment of the current to get a low TC and thus less sensitivity to temperature variations. Keep in mind that the optimum current depends on the temperature - so it could be a different value with the added foam.
To check if the variations are temperature related one cold also monitor the forward diode only. This might also help to find the right current.
Offline Gyro
« Reply #187 on: November 18, 2016, 10:13:10 pm »
Just a thought, is the Red dot on the package (if the same as zlymex's photo) added on test to indicate which diode has the most stable zener breakdown characteristics?
Best Regards, Chris
    • A.N.T. Audio
« Reply #188 on: November 18, 2016, 10:16:30 pm »
I disagree. The temperature fluctuations are on the order of 50ppm/C or less. I didn't have time to find a better current as every time the current is changed the zener changes the temperature and it takes a while to get to the optimum point. But that is possible to resolve in various ways. Most important for me is how smooth the curve is. The LTZ1000 under similar conditions looks mush more "rugged" (though completely flat  ;) ).
Cheers
Alex
Online edavid
« Reply #189 on: November 18, 2016, 10:39:39 pm »
All of mine have the dot on pin 1 (near the tab).
Offline technix
  • Country: cn
  • From Shanghai With Love
    • My Untitled Blog
« Reply #190 on: November 19, 2016, 05:41:26 am »
That dot is used to tell parts apart when you ordered it in unmarked form. 2DW233 got a yellow dot, 2DW234 red, 2DW236 grey.
The following users thanked this post: elecdonia
Offline Gyro
« Reply #191 on: November 19, 2016, 11:07:12 am »
Thanks technix, that makes more sense, I haven't seen the package part number lettering yet (maybe today with luck)  It also clears a small nagging worry that the dot might mean 'reject' (in the same way that die testers do on a wafer) :D. It looks as if the target zero Tc current for these parts will be closer to 10mA (2DW234) rather than 7.5mA then, that should save some time.
« Last Edit: November 19, 2016, 11:10:40 am by Gyro »
Best Regards, Chris
Offline Seekonk
« Reply #192 on: November 19, 2016, 04:04:58 pm »
[/quote]
[/quote]
So, they are all marked 2DW232 and the red dot makes them a 2DW234.
Now the work begins.
Many thanks to zlymex  and VintageNut.
Online edavid
« Reply #193 on: November 19, 2016, 04:13:44 pm »
Wait, he didn't say that!
zlymex or technix, what does it mean when the part is marked 2DW232 *and* it has a red dot?
Offline technix
  • Country: cn
    • My Untitled Blog
« Reply #194 on: November 19, 2016, 05:29:51 pm »
I will confirm it with the factory next Monday. Stop using it for now though, they may be technically counterfeits.
  • Country: cn
« Reply #195 on: November 20, 2016, 05:23:19 am »
Dotted pin is negative terminal, un-dotted pin(of 1 or 2) is positive terminal, pin 3 for reserve. This is from a datasheet.
Red dot is for 2DW232, yellow dot is for 2DW233, pink dot is for 2DW234, green dot is for 2DW235.
Offline technix
  • Country: cn
    • My Untitled Blog
« Reply #196 on: November 20, 2016, 06:43:12 am »
Maybe we are referring to a different datasheet? I have obtained a full catalog from the factory and it have said none of that.
  • Country: cn
« Reply #197 on: November 20, 2016, 06:49:45 am »
Offline technix
  • Country: cn
    • My Untitled Blog
« Reply #198 on: November 20, 2016, 10:35:08 am »
This is definitely a different datasheet I am referring to. I have posted a translated datasheet based on what I got.
Offline BravoV
  • +++ ATH1
« Reply #199 on: November 20, 2016, 12:35:57 pm »
So there are "multiple" different datasheets spreading in the wild ?  :palm:
