I have a MAX-M8W-0-10 module running on a small adapter PCB I designed and built. When I connect to it using U-center, it's initially at 9,600 Baud. I can use U-center to send a message changing the Baud rate to 115,200 and then I have to change the Baud rate setting in U-center before the MAX-M8W-0-10 is 'seen' again by U-center.
What I want to do is save the Baud rate (and maybe other) settings in non-volatile flash so that the module starts up with the changed Baud rate etc. So far I've failed to do this.
In U-center, if I have the module running at 115,200 and I then go to serial settings and change to 115,200 (yes, the same Baud rate) and hit send then it is still connected and gives me a prompt to save the settings which I accept but they don't persist through a full power cycle.
Any suggestions or ideas why it isn't saving?
