Author Topic: The LTFLU (aka SZA263) reference zener diode circuit  (Read 208741 times)
Offline dr.diesel
Re: The LTFLU (aka SZA263) reference zener diode circuit
« Reply #100 on: March 27, 2016, 01:13:30 pm »
zlymex, is it possible to take higher res die photo?
Offline zlymex
  • Country: cn
« Reply #101 on: March 27, 2016, 02:40:58 pm »
I found that photo on the web :)
Offline plesa
« Reply #102 on: March 27, 2016, 02:46:23 pm »
BU508A offered one LTFLU which he purchased for teardown, It it will be genuine we can have hires photo soon.
Offline zlymex
  • Country: cn
« Reply #103 on: March 27, 2016, 04:57:20 pm »
Good news. I have several pieces of SZA263/LTFLU-1 but very reluctant to tear them apart. :o
Offline plesa
« Reply #104 on: March 27, 2016, 05:01:23 pm »
We will see. There are some Fluke DMM with LTFLU, but I did not find it cheap enough on ebay for this experiment.
Offline dr.diesel
« Reply #105 on: March 27, 2016, 05:38:19 pm »
If we don't end up with a high res photo from BU508A I've seen the Fluke DMMs sell for ~130 on ebay.
I'm willing to de-lid for the cause.
Online Kleinstein
« Reply #106 on: March 27, 2016, 08:44:26 pm »
I think there are die photos of the real LTFLU around somewhere.
The question would be if the cheap Chinese ones are real - if they are not and not working very well, than not much is lost to tear one apart. This might even if give a hint on what chip is inside and maybe even make use of them at all, even not as the original.
Offline manganin
« Reply #107 on: March 27, 2016, 10:02:46 pm »
I received today the 5 "LTFLU-1ACH", here are some pictures of them.
Any suggestions / ideas?
1. Fake. Another chip which has the same 4 pin package. Easy to measure if the behaviour is totally different from the LTFLU. Any candidate for a cheap 4 pin metal can IC?
2. Fake. Built from a zener and a transistor. Requires tools for welding the metal can. Correct function but poor stability.
3. Fake. Another chip with the same function. The original Motorola version was freely available and manufactured a long time and in large quantities. But the housing was a little different? Maybe some Chinese or East European copy exists?
4. Real. Fluke and Keithley multimeters are manufactured in China nowadays. Even if real, certainly not the highest grade and possibly even rejected.
Offline zlymex
  • Country: cn
« Reply #108 on: March 27, 2016, 11:34:18 pm »
I once bought five LTFLU-1ACH with date code 9515, they looks the same as BU508A's. Functionally are all good by test and two of them were being used in DIY of voltage references with very nice performance. By adjusting the resistors at the collector, a near zero tempco can be achieved. There is this DH80417B in one of my 731A transfer standard, was that made by Motorola?
Offline Dr. Frank
Offline zlymex
  • Country: cn
« Reply #110 on: March 28, 2016, 08:29:09 am »
Thanks Frank for the photo. Indeed the same reference IC inside TI's plastic container. I have two Fluke 335Ds but never dare to open those TI modules to see what inside. However, I find photos of other TI modules with Motorola SZA263 inside.
Offline fitzfish
« Reply #111 on: April 05, 2016, 06:51:26 am »
Hello everyone,
My first post here and work is not terribly permitting of time so please be patient If I don't get back to questions in a timely manner...
Perhaps I can contribute some additional pictures of the die. The first is the Motorola SZA236 removed from a Fluke 732A. The second is an example of the LTFLU removed from a calibrator board. You'll have to forgive the picture quality. I don't have a great tool to do this.
Enjoy,
Dave
The following users thanked this post: chickenHeadKnob, Andreas
Offline zlymex
  • Country: cn
« Reply #112 on: April 05, 2016, 08:42:50 am »
Hello everyone,
Enjoy,
Dave
Great photo, Welcome here!
Interesting to see the first photo, the zener and the transistor were separated.
Offline branadic
  • Sounds like noise
« Reply #113 on: April 05, 2016, 05:28:41 pm »
Could someone please explain where the zener can be found on LTFLU and what this multiple taps are for? What is the transistor here?
Computers exist to solve problems that we wouldn't have without them. AI exists to answer questions, we wouldn't ask without it.
Offline zlymex
  • Country: cn
« Reply #114 on: April 05, 2016, 11:26:06 pm »
My guess, red area is two zeners in parallel, green area transistors, blue protection diodes.
Offline plesa
« Reply #115 on: April 06, 2016, 05:59:07 am »
The blue and green areas are pad for bonding wire and probing ( measurement). Similar are on almost all IC including LTZ1000.
I agree that in center area is the buried zener itself and it looks like two mirrored structures.
Transistors are between the blue/green areas and center red area.
Offline saturnin
  • Country: cz
« Reply #116 on: April 06, 2016, 05:28:54 pm »
Since the photo of LTFLU die is not very clear, we can only speculate about its layout.
I attached a picture with my guess (everything is described in the picture, green rectangles are possible locations of transistor(s)). It seems to me the symbol used for LTFLU-1 is rather simplified schematic while its internal structure is more complex.
Offline fitzfish
« Reply #117 on: April 06, 2016, 06:03:22 pm »
A better picture. Not much more I can do with a 30x microscope and a phone camera...
Offline fitzfish
« Reply #118 on: April 06, 2016, 06:07:02 pm »
Thanks Zlymex.
I've enjoyed reading through the zener related threads.
Offline plesa
« Reply #119 on: April 06, 2016, 07:06:25 pm »
It looks like LTFLU is not glued directly to package. I can imagine some thermal insulation material or something to relax stress to silicon.
Offline saturnin
  • Country: cz
« Reply #120 on: April 06, 2016, 07:21:09 pm »
@fitzfish:
That's much better. Very interesting, thanks!
I think stripes at the top and on the bottom of your photo are presumably diffused resistors. They seem to be connected to pads only, so they may be used as a heater during trimming process?
I can also see two structures under the top metal in the center of the die.
It is definitely far more complex layout than the one in LTZ1000.
Offline Gyro
« Reply #121 on: April 06, 2016, 07:45:26 pm »
Definitely right about the trimming fuses, some are blown and others not. There are a couple more in the top left area - in fact there's one on the thick track just above left of the first zener, a 'fuse after trim'?
P.S. Any chance that the long dark structure running the full length of the top of the die is a heater?
« Last Edit: April 06, 2016, 07:49:57 pm by Gyro »
Best Regards, Chris
Offline Gyro
« Reply #122 on: April 06, 2016, 09:48:59 pm »
I was told that the LTFLU has a heater, but Fluke decided not to use it.
Actually, there is another identical 'possibly heater' structure running along the bottom of the die (less clear because of the metalization above). The two appear to be wired in series and are terminated on the second and third pads from top right (1st one is bonded out).
Best Regards, Chris
Offline zlymex
  • Country: cn
« Reply #123 on: April 06, 2016, 11:59:12 pm »
Thanks @fitzfish for the clear photo, not bad at all for a phone camera.
Some of the pads are for binary fuses. :scared:
Only "1" left un-blown, that seems to me not a trim at all, rather, it's a straight forward go(other devices could be the same).
« Last Edit: April 07, 2016, 01:04:41 am by zlymex »
Offline fitzfish
« Reply #124 on: April 07, 2016, 07:34:33 am »
One more... This one uses highly oblique illumination to try to bring out the features obscured by the washout in the previous pictures that used diffuse direct illumination.
The fusible links are different on this sample indicating that they are trimmed for some purpose. Could the two arrays either side of the center band be a large transistor array that are trimmed to match it's TC to more closely cancel the TC of the paralleled zeners?
The fusible links that have been blown shine brightly with this illumination method.
Enjoy!
