Author Topic: Copper binding post shorting straps for low thermal EMF-- Alloy/tempering?  (Read 13324 times)
Offline texaspyro
Re: Copper binding post shorting straps for low thermal EMF-- Alloy/tempering?
« Reply #25 on: November 13, 2017, 04:30:02 am »
I have some prototypes of the 4-post straps coming from OSHPARK.  They are just like the 2-post straps, except are stretched 0.75" in order to reach the second set of jacks.
If they turn out OK and I order larger quantities from China, I might do them on 1mm stock instead of 0.8 mm in order to make the longer fingers a little more rigid.
« Reply #26 on: November 13, 2017, 12:18:03 pm »
..., and lots of thermal mass.
Well that's one of those things that cuts both ways. A small thermal mass reaches equilibrium quickly, but that perforce implies that it all can be knocked out of equilibrium quickly. A large thermal mass can sometimes act as useful thermal lag, and function as a low pass filter on any thermal changes that do occur. Which is going to be best is going to depend on the local thermal environment and its stability on timescales similar to the thermal time constant of your short.
The following users thanked this post: Mr. Scram
Offline tszaboo
« Reply #28 on: November 13, 2017, 01:21:38 pm »
Ready made, 3 boards and you can do 1 with 4 bananas and 2 ea with 2 bananas. https://oshpark.com/shared_projects/yOAPbUZF
Can you tell me the part number + manufacturer of those banana connectors? I've been looking for these for ages.
Offline sarel.wagner
  • Cooking up an Electronix Storm
« Reply #29 on: November 13, 2017, 03:47:27 pm »
Hi, I could only get with M3 stud from RS Electronics:
Multi Contact, 4mm Banana Plug, Gold Plated, 50A
Part details
Manufacturer Multi Contact
Mfr. Part No. 22.1055
https://media.rs-online.com/t_large/F2622028-01.jpg
« Reply #30 on: November 13, 2017, 03:58:00 pm »
Just to point out that Multi-Contact have quite a range of 4mm studs, well worth a look at the catalogue if it's something you ever have a need for.
Offline VacuumindedTopic starter
« Reply #31 on: November 13, 2017, 04:40:51 pm »
Part details
Offline casinada
« Reply #32 on: November 13, 2017, 11:58:31 pm »
 :) They cost around $70 US Dollars for the Keithley parts. The Pomona Shorting bar costs around $3.30 US Dollars.  :)
« Last Edit: November 14, 2017, 12:19:38 am by casinada »
Offline texaspyro
« Reply #33 on: November 14, 2017, 12:21:39 am »
Ouch!   My 4-wire ones should run $2-$3 each.   I'm shooting for $10 for 10 of the two wire ones.  I might do a combo pack of 6 x 2-wire and 4 x 4 wire ones for $10.
Offline tszaboo
« Reply #34 on: November 15, 2017, 02:52:01 pm »
Part details
Thanks. But now I've found the Multi-contact 22.1054 which is gold plated, and metric, and 1/3 the price of the keystone.
Anyway, If you are still looking for banana shorting, I've used the Pomona MDP-S before. Which is only shorting 2 terminals, but it is stackable, so 3 of them should short your meter, if the distance is standard.
Offline macboy
« Reply #35 on: November 15, 2017, 03:20:09 pm »
Part details
Look carefully at the datasheet for the Multi-contact 22.1054 ... In Newark's system the contact material is "Copper" but the datasheet says "CuZn" which is brass. That's probably not what you want.
Offline tszaboo
« Reply #36 on: November 15, 2017, 04:18:43 pm »
Part details
"Lantern-style machined from brass and gold plate. The lantern spring is drawn from copper alloy sheet to provide constant contact pressure and a low resistance."
Offline texaspyro
« Reply #37 on: November 15, 2017, 11:00:48 pm »
OSHPARK has the prototype straps off to the board fab.  They should be back around Dec 8.
Offline texaspyro
« Reply #38 on: November 27, 2017, 07:29:36 pm »
OSHPARK has the prototype straps back from the fab.   They should be here in a few days.  If they check out, I'll send the boards off to China for some quantities.  I did both two post and four post straps.
« Reply #39 on: December 01, 2017, 12:47:07 am »
Got a little stash of these arrived today. 1mm Gold flashed Brass based on slightly magnetic and double spacing 38mm or 1 1/2"
Offline texaspyro
« Reply #40 on: December 01, 2017, 12:52:10 am »
I'd be a little concerned about thermal EMF issues with brass / steel.
OSHPARK has shipped mine.  They should have been here today but did not arrive.
« Reply #41 on: December 01, 2017, 12:55:58 am »
Steel certainly. Brass a little bit. I do have a little bit of Silver Bar left from making High powered batteries but my 'source' of that is no more.
Offline texaspyro
« Reply #42 on: December 01, 2017, 11:20:07 pm »
I got the boards back from OSHPARK...  they did not have any copper on them!   Grrrrr...
Offline texaspyro
« Reply #43 on: December 02, 2017, 05:27:49 am »
It turns out the problem was the polygon boundary line was set to 0 width which caused OSHPARKs .brd processor to time out when generating the Gerbers.  Setting the width to 0.001" fixed it.
The HP3458A has a slightly wider horizontal banana spacing than the vertical spacing and the 4-post strap was rather tight when inserted from the top of the banana jacks.  It fit fine when inserted from the sides.  I tweaked the spacing.  I also added a row of via stitching down the middle of the strap.
Offline MiDi
  • Country: ua
4-wire short - DIY
« Reply #44 on: January 01, 2018, 07:22:42 pm »
Nice, I did not recognize this topic when I finally designed my 4-wire short:
I thought about modifying this for the larger space 4-wire terminals (HP 3457A, 3458A, ...), but decided to not do this simple modification, because a simple PCB screwed down should give lower emf and lowers the price.
Is there already a PCB-design for this?
My design idea (easy to modify for 19x19mm):
« Last Edit: January 01, 2018, 07:26:37 pm by MiDi »
Offline texaspyro
« Reply #45 on: January 01, 2018, 07:43:01 pm »
I just got in the new shorting strap PCBs from OSHPARK.  There is a 4 wire and two wire version.  I'm not going to be selling the boards directly but you can get them here for cheap:
Four wire:
https://oshpark.com/shared_projects/j4Htt3KM
Two wire:
https://oshpark.com/shared_projects/QBeVyK9X
You should use the 0.8 mm board thickness / 2oz copper option.  If you need more than three boards it can be cheaper to download the Eagle .brd file and send it to dirtypcbs.com...  specify ENIG gold finish.
« Last Edit: January 02, 2018, 01:52:33 am by texaspyro »
The following users thanked this post: cellularmitosis, worsthorse, alm
Offline worsthorse
  • aina varma, usein väärin
« Reply #46 on: November 15, 2019, 06:10:34 am »
bump
