I am sorry to post that late, but I was offline due to a surgery some time.
I just read your post.
This error occurs when the internal sources have drifted over time.
You just need to due a "internal source calibration" to solve that problem.
+ Enable calibration (key)
+ go to cal menue
+ select ext cal
+ quit (do not execute)
+ next you will be asked if you want to do the internal source calibration - trigger it
But the 1281 must be powered on at least 48hrs to ensure thermal stabilisation.
Thats the way to continue operating over long periods without calibration.
/PeLuLe
