If you really have found such a simple solution, I'll call you a genius.
I remember many discussions on volt-nuts / time-nuts, which neon replacement to use, as the ignition voltage and pairing was crucial, I think, something like 90V, or so..
The specialty was, as Conrad indicated, that these Neons probably had some radioactive substances inside, to lower this ignition voltage.
But anyhow, if it works flawlessly, then maybe I will repeat your stability tests and maybe replace my Neons also..
I've got an 845AR from late Singer Pharmacy, for a reasonable price (was the sell-out, maybe), and it's working quite ok for my purpose, i.e. autocal of my Hammon 100:1 / 10:1 divider.
Not the least quiet nullmeter, but with a bit of patience
![Popcorn :popcorn:](https://www.eevblog.com/forum/Smileys/default/EatingPopcorn.jpg)
it works very well. Especially the extremely low bias gives good results.
Frank
